Home > Puma (Tdci) > Clutch failure
steveandlooby
England 2008 Defender 110 Puma 2.4 XS CSW Java Black
Clutch failure
Out in my vehicle today and when changing down from 5th to 4th slowing in some really appalling hail storm couldn't get in gear. Coasted to side of road. Swtched off ignition to have think. 2mins later started up again and able to engage gears. After a mile or so same problem but bit more dangerous as approaching a busy roundabout. Once stationary, able to get into gear but no power on release of clutch. Anyone else had this failure? Bit disapointing with only 21,000 miles on the clock.
On a more positive note - a big thanks to Simon driving a red 90. Like me a landi newby. Towed me to a safe spot to await recovery. AND came back later to make sure we were ok. And thanks also to Mo in a black 110. Despite a car full of kids stopped to offer assistance. Wouldn't have happened breaking down in another make of vehicle!
Steve
Post #25333 27th Feb 2010 11:02pm
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Hey there
2 weeks ago i had a similar failure.
It was the old Ford spec clutch that had packed up and they had to replace it with a new spec clutch.
They said something about the springs coming loose and then, depending on where they and how they're lying, you struggle with gear selection, etc, etc.
Post #25360 28th Feb 2010 10:00am
puma130tc
Australia 2008 Defender 130 Puma 2.4 HCPU Chawton White
I had the clutch replaced on my 130 @ 18,000 Km
How do i know that the new type as opposed to the old type was fitted?
It's starting to get the same death rattle it had before, oddly its almost managed to do another 18,000 km!
I'd love to know if there is something stronger to put in there, if it's suffered the same fate as last time.
I was lucky i did'nt get stranded on the side of the road, i complained about a fairly serious rattling noise at idle that went when the cluch was engaged, as well as an even worse noise when as the engine came to a stop having been switched off!
When removed the clutch springs in the drive plate were indeed very loose, infact the cetre plate had started to tear apart where the peened over outer parts are joined together, hence the loose springs.
The new clutch also reduced the drivline backlash at the time.
Question
Post #25471 28th Feb 2010 10:22pm
ralton
If you had your clutch replaced a year or more ago there's a good chance the idiots used the same spec clutch as original. Maybe they can give you a serial number or something?
Once the new spec clutch is in i believe all is well...
Cheers,
Post #25477 1st Mar 2010 5:58am
puma130tc
Thanks for that, your probably right, i'll contact the dealer, see if they have any record of what exactly was fitted.
Post #25538 1st Mar 2010 9:25pm
jst
Re: Clutch failure
Steve
i dont know, i stopped on Fri for someone broken down in a Renault scenic!
Not good about your clutch Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #25546 1st Mar 2010 10:12pm
steveandlooby
Well clutch fixed - what a difference. Drives beautifully now on a new modified clutch. So thats what that clonking noise was!!!!!!! Laughing
Post #25717 3rd Mar 2010 6:54pm
tashkurgan
Ireland
I had exactly the same problem with my MY07 110 at about 40K. The dealer replaced it and it feels totally different now..
>j
btw... The same happened to my old MY03 110 at about 33K
Post #25765 4th Mar 2010 9:49am
Hans
France 2008 Defender 110 Puma 2.4 SW Keswick Green
Cheers,
Can they still order the old spec clutch? I'll get mine replaced in a few weeks and I hope they get the new one. Hans
http://www.orlaya.fr
Post #26303 8th Mar 2010 10:38pm
ralton
I doubt the factory will send them the old spec part, but they may get old stock from your local head office?? I would phone them and confirm they're getting the new spec clutch.
Post #26318 9th Mar 2010 6:54am
