Home > Off Topic > ..
Post #309160 18th Feb 2014 3:09pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
As far as I'm aware from the couple of times we've installed / re-installed an LPG system, the tank should have a non-return valve, so disconnecting it shouldn't be an issue if it was all correctly installed in the first place. The gas should only come out when the all connectors are in place and the valve is released. I think they are supposed to have this feature by law anyway, to help prevent potential for ignition/explosion when filling.
There may be a small amount of gas in the pipework but this shouldn't be too much of an issue as it will just escape to air and disperse over time (just like when you don't get the camping gaz stove lit the first couple of tries!)
I think when we removed my LPG system last time (when we were going over the to td5 dark side) I had about 15 litres left in the tank. It felt like I was losing a bit of money on it as I sold my kit on to someone - but it was actually convenient for them to have a bit of gas in the tank for setting up purposes anyway. Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #309169 18th Feb 2014 3:27pm
JJ
United Kingdom 1987 Defender 110 V8 Petrol CSW Corris Grey
If you do let any gas go please be careful on the location , Lpg is heavier than air and can sit in dips and depressions if not well ventilated so just because it is a gas do not expect it to just "disperse".
Post #309171 18th Feb 2014 3:38pm
Pam W
Thumbs Up I should have said that too.... but I kinda thought it common sense to be doing things with gas out in the open air...and also as we don't have a garage we always have done anyway! Our blog - http://landytravels.com/
Post #309175 18th Feb 2014 3:43pm
JJ
No problem Pam, I don't like to cause offence but thought it better to say something and play safe.
Post #309178 18th Feb 2014 3:50pm
