Home > Maintenance & Modifications > Will re fitting the CAT require a change to a Stage 2 map? |
You will need to contact the tuner who's map it is to see if refitting the Cat will throw the tune out.... If you go through life with your head in the sand....all people will see is an ar5e!!
18th Feb 2014 11:21am |
gambit Member Since: 26 Mar 2011 Location: Sussex Posts: 79 |
contact made...
18th Feb 2014 3:43pm |
What was the answer? Noticed from your previous post who your tuner is.
Would think quite a few may be asking the same question at some time or another..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
18th Feb 2014 5:09pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 797 |
It depends on the CPSI and thus the effect on back pressure from the replacment CAT.
In broad terms - anything with a fixed geometry turbo (or a mechanical none ECU controlled VNT) will generally be ok - but you may loose a fraction of low end response. But any modern diesel (so Tdci) where the control strategy is much more complicated and the calibration uses expected exhaust backpressure - changes must be made to the Calibration to suit the increase/changes in flow (especially when an electronic actuator is used). This isn't a major issue, and just means a bit more time on the dyno to prove out the paper based calculations. In a more detailed view - if we are talking about optimisation - changes to the exhaust back pressure must be accounted for within any calibration so even Td5... but depends how the original calibration was done and if it was optimised for a specific flow rate in the first place. However, before I provide suitable solutions - I'm still waiting to find out all of the new rules and regulations - as stated in one of my previous posts (below). Until I know all the answers, there is no point jumping in both feet - all you are doing is firefighting...
Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
18th Feb 2014 5:58pm |
I know where you are coming from Ian but obviously the date has passed and people are due MOT. I personally can afford to wait as mine isn't for another four months. But those that are due must be keen to set something in place rather than waste the money going for MOT to have a subsequent possible failure by doing nothing.
18th Feb 2014 6:11pm |
Having checked with my MOT tester mate... there is still no guidelines as to what should be fitted with a CAT, what should be fitted with a DPF etc. So they are still in the dark and based on testers discretion. The rule is in force (technically) - but that's it.
A system can not work like that. If it is just the case you need to have a CAT or something that looks like a CAT then just fit a high flow race cat. These are not type approved - but on the 'how long is a bit of string' MOT guide they will give you a pass. What I don't want to do is recommend to all my customers you must fit one of these... then a week later VOSA release a document to say that it is not needed (so wasted money), or must be to 'X' specification. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
18th Feb 2014 6:26pm |
Thanks for the response, certainly helped me understand what is going on at the moment.
As it happens, my MOT is not due until the end of the year, so I have plenty of time I only stumbled across this topic recently, so missed a number of posts in various threads. Am happy enough with the wait and see what this means approach. Cheers, Andrew. |
19th Feb 2014 11:46am |
Ultimately then at the moment it's down to the individual what steps (if any) should be taken to assure an MOT pass. I think your fist suggestion in your last post is possibly the cheapest and most viable option in the interim until we see what 'pans out.' Shouldn't be too much toil either with it's adaption or fitment. Even if I had retained my original Cat it was such a b45t4rd to remove in one piece I don't think with careful consideration I would have gone so far to go so far to refit the original anyway.
19th Feb 2014 12:10pm |
