Home > Puma (Tdci) > Dipped Headlights Stopped Working - help
vaucluse
2007 Defender 110 Puma 2.4 SW Java Black
Started up the truck last night to find my lights have stopped working.
If I move the lever forward once then the dashboard is illuminated and sidelights work normally. But if I move the lever forward to the next position (dipped lights) then the dashboard goes out and so do the sidelights and the main lights do not come on.
Having looked quickly at the fuses under the steering wheel I see that the dipped lights left and right side are fused separately so I doubt both fuses or both bulbs went at the same time.
Anyone had this with their Puma? Hoping someone can perhaps shed some light (no pun intended) to save me some time going over the basics?
Mines a 57 plate TDCi
Thanks in advance,
Mark
Post #307801 13th Feb 2014 6:34pm
K9F
http://www.defender2.net/forum/topic16451....ght+switch
http://www.defender2.net/forum/topic24666....ght+switch
http://www.defender2.net/forum/topic13683....ght+switch If you go through life with your head in the sand....all people will see is an ar5e!!
Post #307802 13th Feb 2014 6:40pm
gprich
Wales 2012 Defender 110 Puma 2.2 USW Orkney Grey
It is almost certainly the main lighting switch (stalk) - same one been used for years so at least it's cheap and available and a fairly easy job to do yourself.
Post #307804 13th Feb 2014 6:41pm
Cheshire110
relay your headlights as per the threads K9F linked too, erases the problem completely for the future.. Cheers, David
Post #307811 13th Feb 2014 6:55pm
K9F
Or replace with LEDs to reduce the current draw through the switch perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #307813 13th Feb 2014 6:58pm
vaucluse
Thanks for the links K9F
So it looks like I need to change the switch as there's no relay right?
How straight forward is this? Plug and play or soldering required? Also does the steering wheel need to come off to do this?
Thanks guys
Mark
Post #307823 13th Feb 2014 7:31pm
No soldering required, it's all plugs. Wheel doesn't need to come off but removing it does make the job a lot easier (it's very easy to remove the wheel).
Post #307830 13th Feb 2014 7:54pm
vaucluse
Many thanks Blackwolf.
That sounds like something I can take care off on Saturday myself.
Thanks to all of you for your replies.
Mark
Post #307838 13th Feb 2014 8:17pm
Josh K
United Kingdom 2007 Defender 90 Puma 2.4 HT Orkney Grey
I had this issue last month and bought a new switch. However when the truck was in for its service whilst awaiting delivery of the part, the garage repaired the switch with some solder so now I keep the switch as a spare in my truck tool box just in case the switch goes whilst out and about. Always better to be prepared, saves having to drive home with the sidelights which far too many members on this site have had to do 2007 (57) Defender 90 (Sold)
Looking for another to replace it.
The road less travelled.... is a muddy one!
Post #307879 13th Feb 2014 9:33pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Better to be prepared and RELAY the lights. solve the problem, not the symptoms
Post #307995 14th Feb 2014 12:44pm
