![]() | Home > Puma (Tdci) > No instruments,limp mode- SOLVED. |
Tewharaunz Member Since: 20 May 2014 Location: Charteris Bay Posts: 10 ![]() ![]() ![]() |
You are a legend!
I replaced the second battery on my 2007 3-door Hard Top 110 and afterwards I completely lost all the gauges and LCD on the instrument panel (except for lights). I was sure that I had somehow fried the instruments but I checked through all the relevant fuses and wires, finally giving up. I searched through defender2.net until late in the evening, after numerous false trails, I finally saw your post. Not completely confident that it would work for me, this morning I disconnected the feed and shorted it to earth and like magic, everything is back to normal. Thanks for posting your solution! |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
By "the feed" do you mean the red + cable connecting to the battery?
So you disconnect both the - and the + cables from the battery and then make these two touch? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Everyone seems to have a different name.
Positive=feed=power=red=+=+ive Negative=earth=ground=black=-=-ive I just loosened and took the cable/lead/wire/connector off the positive battery post and touched it to the negative battery post. I didn't bother disconnecting the negative battery cable. Of course at the time I didn't think it was going to fix anything, but then it worked! Thanks again fatman! I'll definitely keep it up my sleeve for the CANbus system in my wife's Citroen. She loves the fact that I can read and delete codes from her car too. |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
Exact same problem but all I did was to do the "ignition on/off without cranking" routine 5 times in quick succession.
That "resets" all stored faults. All perfect there after. |
