Home > Puma (Tdci) > Gearbox dip stick
martinfiattech
Gearbox dip stick
morning all,
I`am still a bit new to all this and sorry if this has been covered before.
After my defender getting a new gearbox. In couple of thousand miles like to change its oil just to keep everything happy, I was wondering if anyone had made or had drawings of some kind of dipstick affair or bent bit of welding rod for checking its level.
just to save time in future for servicing the car instead of draining and measuring it out.
This no doubt would come in handy for owners of new vechicle`s so they can check there`s some oil in there unless its all on the outside Big Cry
Post #305568 6th Feb 2014 11:48am
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
The Series One and early Series Two's were fitted with a gearbox dip stick, which could be accessed internally from a flap in the transmission tunnel, then along came progress, and it was removed, instead you have to rely on the filler plug hole on the side of the gearbox, accessed from underneath! - Like I say, progress....... Rolling Eyes Euro-Leafing to infinity and beyond.....
Post #305588 6th Feb 2014 1:30pm
Remember though that on the TDCi the filler plug is not a level plug, and you must not overfill the box.
There really isn't any way to check the level - you cannot find out how much oil is in the box. All you can do is drain and refill with the correct amount of oil.
Post #305603 6th Feb 2014 2:18pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I think you need to put 1.2 ltrs of oil in the gearbox
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #305607 6th Feb 2014 2:34pm
ZeDefender
Exactly Thumbs Up
For the 2.4 TDCi a gear oil change needs 2.2l as the "full" capacity is 2.4l but 0.2l remains trapped inside Tell someone you love them today because life is short.
Post #305611 6th Feb 2014 3:12pm
big steve
Ahh sorry ze defender it was a long night I new it was something .2 remembering back now it was just over 60quid for 3litres
Post #305614 6th Feb 2014 3:33pm
ZeDefender
Yeah - the cost is horrifying for decent stuff Big Cry Tell someone you love them today because life is short.
Post #305615 6th Feb 2014 3:56pm
martinfiattech
Thanks guys at least some of us now know its not a fill to level type affair.
Will knock one up next week when on early shift and let you know how I get on, this may be a good excuse to play with the lathe Very Happy .
I`am going to assume mine is at the correct level in the first instance make tool then drain box measure fluid drained off put it all back in and check.
Post #305817 7th Feb 2014 8:45am
MartinK
I'm sure it's only a few mm (like 3 or 4 mm) down from the filler plug.
Some people have "topped up" to the filler plug with no apparent issues (indeed stories of better gearchanges!), and said that it only took a small amount of oil from the 2.2 litres to the filler plug... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #305819 7th Feb 2014 8:54am
Be careful if overfilling - there are many stories of gearboxes running very hot indeed if overfilled. Also many stories of gearboxes overfilled from the factory of by dealers.
There is a reason why LR specify 2.2L, not 'fill to plug' (possibly the tail-down attitude of the box).
If you want a "better" gearchange you are better filling with the correct amount of a better oil, rather than simply more of the standard oil.
Post #305828 7th Feb 2014 9:36am
MartinK
Or...as dgardel does, add ceramic additive http://www.defender2.net/forum/topic2139.h...ox+ceramic Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #305838 7th Feb 2014 10:21am
munch90
when I changed mine I got over 5 litres out!!!!!
yes think someone got carried away , must have been like it from new or pdi as its never been back to dealer or any garage
Post #305842 7th Feb 2014 10:31am
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
hi,
I do not understand why they did change, it was so easy to verify the level before !
I forget to see at what level it was when new, otherwise if I know who much under the hole, it is ok for me
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #305846 7th Feb 2014 10:50am
ZeDefender
martinfiattech wrote:
I am going to assume mine is at the correct level in the first instance.
Er...probably shouldn't do this - other members have had nasty shocks.
Just drain the oil (making sure you can remove the filler plug first!), make the volume up to 2.2L, and use that as your guide. Good luck.
Matt Tell someone you love them today because life is short.
Post #305855 7th Feb 2014 11:46am
