Home > Td5 > Can i reuse Hub nut
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
Can i reuse Hub nut
hi all, doing wheel bearing on a td5 90 (2003) still has the spacer bush set up, can i reuse the hub nuts or am i going to have to relace? cheers ed
Post #305376 5th Feb 2014 8:10pm
landy andy
Good practice is to replace with new each time.
Andy
Post #305384 5th Feb 2014 8:38pm
grafty99
whilst I agree it is good practice to renew AND I converted to Tdi type when I did mine, they will go again, with care Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #305392 5th Feb 2014 9:01pm
landy andy
You can keep the spacer system, but change to the two lock nut system, if you don't want to go the full job.
Andy
Post #305394 5th Feb 2014 9:04pm
Millsy94
thanks all does anyone know what the procedure is with the spacer system? do you just nip the nut or really tight? cheers ed
Post #305402 5th Feb 2014 9:24pm
landy andy
Really really tight. That's one of the reasons a lot of people remove them.
Wrong figure removed Rolling Eyes
Andy
Post #305408 5th Feb 2014 9:36pm
Millsy94
jesus!! i was told 210nm and thought that was eccesive
Post #305412 5th Feb 2014 9:41pm
landy andy
Just looked somewhere else and got
" fit stake nut & tighten to 210Nm or 150lbft"
That sounds better
Sorry
Andy
Post #305413 5th Feb 2014 9:43pm
Millsy94
Have you removed your spacer i presume?
Post #305415 5th Feb 2014 9:46pm
landy andy
Yes removed mine on my Td5, and will do on my Tdci when I do work in that area.
I found it very difficult to set the bearings correctly with out having spacers available, then assembling dry, testing for play then if correct, dissemble grease then reassemble. When I went for the "old spacer will be near enough route" I got play in bearings once they had settled.
Andy
Post #305420 5th Feb 2014 9:54pm
Just overhauled my front axle due to a disintegrated halfshaft and can confirm that the correct torque figure for the hub nut (spacer system) is 150 lbft.
The stakeable hub nuts shouldn't be reused, but can be in an emergency provided that they are not damaged when "unstaked". If there are any breaks, tears, or similar in the collar that you stake, you must replace them. Beware Britpart nuts - I bought four a year ago which don't fit the stub axles (they will in fact destroy the thread on the stub axle if screwed on - ask me how I know)!
If you opt to replace the single nut with the earlier two nut system but keep the spacer, then torque the inner nut to 150 lbft in the usual way.
If you ditch the spacer you must go to the two nut system and adjust the old fashioned way (ie don't torque to the above figure - if you do you'll destroy just about everything)!
IN my case after removing the halfshaft fragments I have had to strip and inspect the Ashcroft ATB to make sure that it wasn't full of fragments. A very well-engineered bit of kit, I just keep being more and more impressed with it!
Post #305553 6th Feb 2014 11:02am
