![]() | Home > Maintenance & Modifications > Top Up Front Swivel Housings |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
If swivels are not leaking then the oil seal between them and the diff is gone. In such case your diff oil should look darker than GL-5 oil. The one-shot grease is NGLI00, i.e. lower viscosity than normal chassis grease (NGLI2). Anyway it should be about 1/3 full. Puma 110" SW
rob369 Member Since: 05 Feb 2014 Location: eastbourne Posts: 17 ![]() ![]() ![]() |
Thank for the input MK, your defender looks great in white. rob369
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
I soak the sachet of grease in very hot water, before you use it, it makes it much easier to do
![]() Andy |
