![]() | Home > Puma (Tdci) > Fitting a decat pipe .. on the drive |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2674 ![]() ![]() |
exhaust place... i found it quite tricky.
With the crossmember and front propshaft disconnected the catalytic convertor can be removed on the drive. The engine itself may need pressure applied with a jack to give you the extra 5mm room to manipulate the cat out. It can be difficult but achievable.
Few tips.... http://www.defender2.net/forum/topic26399.html ![]() Treat every day as if it is your last....one day you will be right!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20964 ![]() ![]() |
The x member can be a pain to remove sometimes so I've heard, but not always.
I've just left my cat as standard and put in a straight trough centre section. Can't be bothered to be honest. ![]() Modifying cats what next birds? ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
