Home > Puma (Tdci) > Rear Cross Member
MJP
Wales
Rear Cross Member
Is it sufficient just to paint a crossmember on a new 110 without additional rust prevention treatment?
Post #302964 28th Jan 2014 9:30pm
Cheshire110
make sure its all completely clean, get some alcohol/paint prep wipes on it
get a few coats of decent paint on top (probably won't need primer if its pretty new)
let it dry thoroughly and then buy a can of waxoyl or equivalent and get it in every hole and in every section from every angle
job done! Cheers, David
Post #302969 28th Jan 2014 9:36pm
Caterham
not quite job done.....
clean it every week with shed loads of wd40
Very Happy
Post #302974 28th Jan 2014 10:03pm
MartinK
I prefer ACF365 to WD40...ACF doesn't attract dust... Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #303069 29th Jan 2014 10:39am
x-isle
If it's not that bad, which suspect it isn't but looking a bit tatty, then yes, you'll be fine.
You say new, but why would you paint a new one? That'll probably void the warranty?
Here's how I did mine that wasn't that bad.
 Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #303074 29th Jan 2014 11:05am
