Home > Maintenance & Modifications > Sunroof questions....
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I'm deliberating over fitting a sunroof to my Td5 90.
Questions.....
Any recommendations on make or style?
Will I need a new headlining?
Do they all leak?!!
I've heard a few stories on water ingress and wondered if true
Post #301877 24th Jan 2014 9:30pm
Lou Sparts
Two of my ninetys have had factory fitted sunroofs neither of which leaked, However condensation does form on the inside of them in cold weather which drips off when you go over a bump !
Current Ninety has no sunroof but headlining appears to have the shape of one moulded in to it which you could probably cut out. 2005 Td5 90 XS
Steve
Post #301882 24th Jan 2014 9:45pm
GUM97
Have a word with Dave @ LandyGlass. Top class service, he sorted me out for mine Thumbs Up An engine to TDi for!
Post #301891 24th Jan 2014 10:15pm
Alex1976
I fitted a genuine sunroof to my 90 last year and it was easy. Just measure twice and cut once (both the roof and headlining) and then it is all striaght forward.
I used Sikaflex to seal the sunroof frame to the roof and I had had no leaks at all. You do get some condensation though when it is cold, but this soon goes as you get driving and it warms up.
I really like having the sun roof, and it is really good on cold days with the heater on but sunroof open a bit for fresh air and also this demists the interior super quick.
Post #301892 24th Jan 2014 10:15pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I have the factory fitted sunroof and it's perfect in every way, no leaking and no noise when moving a speed.. only one exception.. I can't turn left in the winter as the condensation drips off directly on either my head or gentlemen area. If a passenger is on-board, can't turn at all. I currently keep a cloth next to the hand held window wiper to dry it before journeys Thumbs Up
Post #301898 24th Jan 2014 10:24pm
SFDM
England 2008 Defender 90 Puma 2.4 XS CSW Bonatti Grey
As an alternative
( not the most attractive of voices! )
Know someone who has the front one which is also linked to the central locking Ne nostra in fundamenta subeamus
Post #301946 25th Jan 2014 1:38am
JWL
That is one hell of an accent, it was really hard to watch it to the end, was better with the sound off Whistle
Post #301947 25th Jan 2014 1:51am
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
You need to get out more Rolling Eyes Wink I would have said she had a very mild accent there... for Essex.... Not much of one at all! Her voice was ok, good diction and inflection.... No problem to listen to for me....
Have having worked at tourist attractions and in education with people from all over the UK / World, maybe I'm just more tuned in though... Whistle Very Happy Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #301973 25th Jan 2014 10:07am
alfajock
United Kingdom 1989 Defender 110 V8 Petrol CSW Bonatti Grey
Ah, the diversity of Defender ownership - I've just had my factory one removed, plated over and the whole roof seam sealed!
After five years of getting leaked on, condensated on, and having to remove the seat base every time I leave the vehicle in case it rains the seat gets soaked, it is bliss!
So as you might expect, I'm in the "don't do it" camp Laughing Fully Restored 89 110 CSW V8
CLS 350 CDI for the sensible stuff
Post #301988 25th Jan 2014 11:12am
JWL
@ Pam, after entering the world in deepest Gloucestershire, moving to Warwickshire where they mostly speak the Queens English and now living in 'Yerefud I've been subjected to some of the countrys softer accents. That womans voice sounds like a castrated alien on helium Whistle
Post #301989 25th Jan 2014 11:19am
Lambley
Thanks for the above replies, looks like it's about 50/50 at the moment, I don't want to do it and regret it, I think I'll leave it for now but thanks again.
Post #302028 25th Jan 2014 4:31pm
geobloke
I have a factory sunroof fitted to my 2002 110 and I love the extra light it lets in to the cab. As with a few others mine does not leak at all, but in cold weather it does provide the perfect surface for condensation to form on. Depending on how cold it is depends on whether you get dripped on or an icicle down the back of your neck. There is a strange satisfaction in the shrieks of your unprepared passengers... Whistle Whistle
I have found that it is a great idea to clean the seal once a year, just before winter, and apply some silicone spray to the seal. I do the same for the door seals as well and have not had any significant freezing related tearing since doing it.
Post #302218 26th Jan 2014 11:31am
H3nry
Hi,
I was told the current webasto 300 is a lot better compare to the older version.
An experienced installer and regular maintenance (once a year?) should be trouble free?
I'm considering...still 50-50...
Post #302326 26th Jan 2014 5:20pm
Lambley
Thanks again for the replies, so....
If I had a fairly simple tinted glass sunroof that was able to tilt open, nothing electric or fancy, would I be able to use the headlining I have at the moment?
Post #302383 26th Jan 2014 8:30pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
If it is condensation, then having a de-humidifier in the vehicle may have a significant effect.
This is what I mean - http://www.amazon.co.uk/s?ie=UTF8&fiel...ch-type=ss Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #302392 26th Jan 2014 8:54pm
