Home > Technical > Puma 57 blowing starter fuse
Loud40
Wales
Hi everyone, ive got a bit of bother with my 57 90 puma, she now and again blows the 40a fuse under the drivers seat, would happen maybe four times a day, then maybe once a week, really strange....? When she does it all the electrics would work except she wont turn over...?!
Would anyone know how i would be able to get my hands on a starting circuit diagram by any chance?
Thanks louis.
Post #301380 22nd Jan 2014 11:05pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Hi Louis,
Dgardel is our resident font of knowledge with wiring diagrams and workshop manuals etc.
Check out THIS THREAD for more info.
Which actual fuse is it that your blowing? One of the screw down fuses?
Post #301381 22nd Jan 2014 11:11pm
Loud40
Wales
Hi Phoenix90
Thank you very much for the info, its the single 40a blade fuse next to a 60a slow blow blade (the biggest type blade) the two are on theire own little bracket under the drivers seat, not in the fuse box... Really annoying, as it might be fine for weeks and then blow four in one day :-/ Ive replaced the wire running from the starter relay to the starter solenoid and so far no blown fuse yet.... Fingers crossed lol
Post #301694 24th Jan 2014 9:01am
Do you mean these fuses (faintly ringed at bottom of photo)?
Post #301699 24th Jan 2014 10:03am
Loud40
Wales
Hi mate, yea its the small blade next to the big blue blade fuse
Post #301714 24th Jan 2014 11:26am
K9F
Not wishing to state the obvious here but looking at the electrical diagrams there isn't a 40 amp fuse in the starting system.
Whistle
The battery junction box contains (or should contain the following):-
Link 5 - 60 amps Relay Starter.
Link 2 - 60 amps is your Instrument Cluster feed which is protected in series with another fuse Fuse 30 in your Central Junction Box which is rated at 10 amps.
Fuse 5 - 30 amps Relay Main.
The smaller fuse supplies the coil of your glow plug relay Relay 14 when the ECM commands it. (Ignition on).
Hope this helps.... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #301735 24th Jan 2014 1:01pm
I've never been able to figure out what those two fuses actually protect, and can't find them in the circuit diagrams. I had a suspicion that the larger one was connected in some way with the injectors, but I am not sure.
Sorry it's not much help!
Post #301757 24th Jan 2014 2:15pm
astoltz
South Africa
From the Electrical Connector Manual the small one is: c0602
a 15Amp Fuse connection to the Engine ECU
The big one is a 60Amp fuse for the glow Plugs
http://4x4community.co.za/forum/showpost.p...ostcount=1
Abrie 1997 Land Rover Defender 110 HT 2.8i
(BMW M52)
2009 Land Rover Defender 110 HT 2.4 TDCi(Puma)
Post #301916 24th Jan 2014 11:00pm
Thumbs Up
Post #301922 24th Jan 2014 11:22pm
Loud40
Wales
Hi K9F Yea, its a really strange one... The diagrams doest seem to show the 40A fuse clearly.... I traced the wire going out from the 40a fuse to the starter relay, and it goes through the starter relay when its energised, straight to the starter solenoid.... Ive run a new wire from the starter relay to the starter solenoid and fingers crossed the fuse hasnt blown yet Smile
Thanks everyone for the help!!! Thumbs Up
Post #302062 25th Jan 2014 6:28pm
K9F
Question The fuse that protects the starter relay(R102) contact supply is Link 5 mentioned in my previous post which should be 60 amps?
Here's the handy link from Dgardel with loads of useful information and the wiring schematics too.... Thumbs Up
http://api.viglink.com/api/click?format=go...7269580318 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #302185 26th Jan 2014 10:00am
