Home > Puma (Tdci) > Transfer Box or Clutch Failure??
Whitewaitress
2007 2.4tdci 110 Hard Top Puma on ~100k miles
Perhaps someone may have experienced a similar issue here - whilest out driving a few days ago I was changing down through the gears coming up to a set of lights when I heard a squelching noise and something clunk/knock hard from underneath.
After this I was able to limp home with a very loud whining from the gearbox/transfer box through the vehicle - closer to home when stopping at lights I would pull off gently and I could feel a slippling between the revs and the output at the wheels as if something between the clutch / gearbox / props was not engaging and here the knocking/screaching noise was coming from.
When I put the vehichle into neutral and roll the clunk/knock is still there and can be felt when it hits as if the brakes are given a sharp stab. When pulling off gently now to move it about the transmission will almost lock and I cannot push any further past this point.
Could this be a transfer box issue, or a clutch that has broken? Or even a front or rear diff?
Any guidance as always would be much appreciated.
Post #300527 20th Jan 2014 11:11am
geobloke
The only way you are going to be able to tell where the clunk clack bang is coming from is by jacking up a wheel and turning it by hand, listening for scraping clunking noises. It may be neither the clutch nor the transferbox... Could be one of the differentials, or a UJ or indeed the transfer brake. Just remember to chock your wheels before jacking then release the transfer brake. Let us know how you get on.
Post #300530 20th Jan 2014 11:20am
Whitewaitress
Thanks Guy,
I will check the movement in the wheels, the noise sounds exaclty like that in this youtube video at around 16 and 40 seconds. The clatter and screech are very similar.
Cheers,
Rob
Post #300572 20th Jan 2014 2:11pm
bob neville
Hi Rob
Have a read, not saying it is this but there have been a few with the same problem.
http://www.defender2.net/forum/topic11955.html
2013 Defender 90 CSW - sold
Post #300577 20th Jan 2014 2:33pm
geobloke
Whitewaitress wrote:
Thanks Guy,
Cheers,
Rob
If you cannot hear anything it would be a good idea to dump the oil from the axles first, then the transferbox and see what comes out. If something has gone then you should see chunks in the oil and the diff pan or transfer box. Open up the filler plug as well and shine a torch in there too, if the gears have eaten themsleves it will be very obvious.
I suspect it is not the front diff as having had that go on my 2002 110 you know when it does.. rear wheels almost came off the ground when that seized up.
This is what it looked like when I drained the oil and took the diff out;
[URL=][/URL][URL=][/URL][URL=][/URL][URL=][/URL][URL=][/URL][URL=][/URL][URL=][/URL][URL=][/URL][URL=][/URL]
Post #300583 20th Jan 2014 2:55pm
Whitewaitress
Cheers guys - not had chance yet to investigate any further, although one of the guys who works over the road from me seems to think its the splines on the main shaft that comes from the gearbox, and that they have worn with them not bein lubricated. He took a quick listen and came up with this diagnosis straight away.
I will keep you posted - fingers crossed the transfer box isn't another made of cheese!
Post #300841 21st Jan 2014 1:42pm
bob neville
That was exactly the problem I had and posted in the link above. The shaft goes before the transfer box - hopefully !
Not uncommon.
Post #300849 21st Jan 2014 2:18pm
Whitewaitress
Cheers Bob - I did find your thread useful reading - I'm hoping that is the extent of the problem and nothing further!!
Post #300884 21st Jan 2014 3:59pm
If your failure was the adaptor shaft I doubt you'd have any drive at all.
I can say this with some confidence since I am writing this while waiting for the RAC to come to take me home after suffering an adaptor shaft failure. Big Cry Big Cry
Post #300941 21st Jan 2014 6:23pm
Whitewaitress
Quick update for those who have posted / read this thread:
Problem was the transfer box - the internals had shattered to bits - could have been caused by one fragment coming away from a cog or bearings failing. I'm not completely sure.
I had hoped it would be a mainshaft but sadly it wasn't!!
It's worrying that you could be plodding along anywhere in the world and something like this go 'bang' on you!!
Thanks to all of your input guys!!
Post #308729 16th Feb 2014 9:40pm
