Home > Td5 > Vibration at 50-60mph
aus10RRW
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
When my 90 reaches 50-60mph, I get a serious vibration through the vehicle. I put it down to wheel balancing being off, but when I dip the clutch and freewheel at the same speed, theres no vibration??
Im beginning to suspect the clutch or flywheel has anyone come across this before??
Post #300156 19th Jan 2014 1:55am
JWL
There can be many causes, lots of things to get out of balance and as you've said the wheels and tyres can be a big contributor. Suspension bushes are another fravourite and can cause vibrations at different speeds, propshaft joints, usually felt when under load i.e. acceleration and decceleration. Wheel bearings and swivel bearings can cause the odd wobble but as you say that when you dip the clutch the first port of call would be propshaft joints, I'd be looking at the easily accessible bits first.
Post #300160 19th Jan 2014 2:28am
landy andy
I'd start with prop uj's. Remove a prop and check joints, whilst off have a test drive, grease the uj's, and check weights are still attached. Replace, test drive, then the same with the other prop.
Andy
Post #300166 19th Jan 2014 6:06am
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Almost certainly UJs. Get underneath and give them a good wiggle. If nothing found, take them off and wiggle them on the bench. Should quickly find the offending one(s)
Post #300597 20th Jan 2014 3:40pm
aus10RRW
I'll give them a check when I get back to the UK next week.
Cheers guys! Very Happy
Post #301114 22nd Jan 2014 1:15am
Ragerover
You can often check uj's by lying on your back and putting late rep pressure on it
You have to move it through 90 degrees as often it's worn in 1 direction
Post #301122 22nd Jan 2014 8:30am
DCFerret
England 2003 Defender 110 Td5 DCPU Epsom Green
Re: Vibration at 50-60mph
My Defender is currently in "hospital" after suffering from the exact same problem......gearbox and transfer box are knackered and causing it so being changed. Flywheel was suspected but is still in very good condition.
Post #301527 23rd Jan 2014 5:00pm
aus10RRW
I really really hope its not the transfer/gear box!! Big Cry Big Cry
Already spent a load on the 90, this is last thing I need!!
Post #303030 29th Jan 2014 12:29am
Diablo
Have you not checked the UJs yet?
If they are badly worn, you could end up damaging the yoke on the propshafts, or worse - you don't want a propshaft digging into tarmac at 70mph
Post #303128 29th Jan 2014 3:59pm
DCFerret
Hopefully yours won't be the transmission. My 110 is now all back together and still had a vibration that the garage weren't happy with and have traced it to the rear prop shaft, new UJ's have made no difference so they're waiting on a new prop to come for it which should hopefully cure it.
Post #303261 29th Jan 2014 10:24pm
aus10RRW
Well finally got the 90 into the garage when I got home and the rear U/J was completely gone!! Replaced the U/J and shes running sweet as now!! Cheers for all the advice!! Very Happy Very Happy
Post #315919 14th Mar 2014 2:37pm
