Home > Maintenance & Modifications > Going deeper than 500mm
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Just reading a recent post that explained in great "depth" (ha ha) that in a 2.4 puma, you cant go deeper than 500mm which suprised me. I have a RAI which is sealed on the bodywork. But, the question is what else do i need to do. I see all these you tube pics showing water coming over the bonnet, what mods have they done. BTW i have wading blanket over the grill.
Post #299836 18th Jan 2014 9:37am
Cheshire110
I think the 500mm depth is a sort of 'max definitely safe' limit...
Above that if you're stationary you could run into problems with electric fan, electric throttle etc but if you push a now wave if say you're safe up to the wing air intake at least, I wouldn't take mine any deeper
Certainly you see pumas with footwells full of water keep going, but I wouldn't want to put the throttle underwater for sure!
As a general rule for myself , I try and keep the sills out of the water but I've seen much deeper. Also you'll throw water around the engine bay at depths where the sump is underwater Cheers, David
Post #299868 18th Jan 2014 11:24am
Cheshire110
See here for some fairly deep wading by a 110 and some other vehicles- puma opens doors to let water out but had no problems...
 Cheers, David
Post #299870 18th Jan 2014 11:28am
g-mack
Re: Going deeper than 500mm
prepare to be dazzled!!!!!!!!!!!!
puma with water up the windscreen!!
 My 109 thread
my youtube channel
Post #299874 18th Jan 2014 11:59am
g-mack
just thought i would chuck in this tdi one for your entertainment too!!!
&list=UU4fdjZ6b7-vf1h0X8kDRr_Q&feature=c4-overview My 109 thread
my youtube channel
Post #299880 18th Jan 2014 12:19pm
leeds
I could not readily find the video of the Royal Marine standing up to drive a Defender through deep sea water from a landing craft.
However there is this one
Personally I try to avoid sea water as much as possible!
Brendan
Post #299888 18th Jan 2014 12:50pm
Laurie
Post #299892 18th Jan 2014 1:03pm
or a unimog Thumbs Up
Post #299909 18th Jan 2014 2:02pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Bigger wheels and a lift kit would increase the safe wading depth. http://defender90xs.blogspot.co.uk/
Post #299910 18th Jan 2014 2:04pm
Cheshire110
looking at that, although he may have a RAI, it can't be good having a dash full of water with a puma! his heater intake etc were all underwater and seeing the water pouring out from behind the dash makes my skin crawl! Cheers, David
Post #303144 29th Jan 2014 4:56pm
g-mack
yep leave that kinda stuff to the pre td5 mob! at least it shows it got through, wonder what issues it caused him afterwards though My 109 thread
my youtube channel
Post #303164 29th Jan 2014 6:28pm
...or might be worse if they allow vehicle to float or even just reduces weight/traction on underwater surface?
Post #303478 30th Jan 2014 7:00pm
mark_d
If you go to 38/15.5/15 wheels then it may be an issue, but you could increase wading depth by a couple of inches by going to something like a 265/65R18. Using larger rims means you get a bigger diameter without displacing too much extra air.
A lift will have the opposite effect, reducing buoyancy at any given depth since less of the body will be submerged.
It won't turn the vehicle in to a submarine, but it could give you the ability to go 6 inches deeper before your feet get wet. On the down side, it will restrict the number of car parks you can use. http://defender90xs.blogspot.co.uk/
Post #303637 31st Jan 2014 6:50am
jst
think about extending the breathers for mech components and tank too, plus ECU locations,
engine - bulkhead
ABS - under drivers seat
DPF - under drivers seat
td5 - ECU under seat
pre tdi - less electrical bits to worry about Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #303674 31st Jan 2014 10:32am
http://www.telegraph.co.uk/motoring/news/1...escue.html
Post #305834 7th Feb 2014 10:15am
