![]() | Home > Td5 > Wipac Crystals and Nightbreaker bulbs fitted.... |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1138 ![]() ![]() |
After my recent headlamp fail on a dark road which was caused by the dip switch melting, decided to replace the original headlamps with some new crystals. Dead easy to do, and a real difference in performance. Highly recommended.
![]() 1966 S2a 109 aka Betsy |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
obviously you changed the switch, did you incorporate some relays into your wiring?
+1 for wipacs and uprated bulbs, I did that before changing to led headlights, huge difference without huge expense ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Yes new switch fitted. I have not yet put a relay in, but intend to very soon. 2021 Defender 110 X-Dynamic HSE D300 MHEV
