Home > Wheels & Tyres > Best 30mm Wheel Spacers, advice please ?
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
As the Subject, who supplies the best or does it make any difference ?
Thanks Guys
CR
Post #298800 14th Jan 2014 8:20pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
I think mine are Bulldog ones, quality wise they look and feel well made. Ive had them on my 300tdi and 2.2 for a few years and never had any problems. Thumbs Up
Post #298802 14th Jan 2014 8:24pm
What puddle?
CR. I have just fitted mine. I looked at getting steel for the strength, but they are VERY heavy (25kgs!). I read up a lot and people swear by the strength of billet aluminium (whatever that means). I saw lots of silly prices, but finally got Bulldog ones for £110 from http://www.simonbbc.com/wheel-spacers/land...-set-of-4. Sent by overnight courier too - included in the price! Make sure you use a torque wrench set at 143 KGM. If you haven't got one, Screwfix sell one for £24. Now left.
Post #298807 14th Jan 2014 8:34pm
Laurie
......and make sure you tell your insurers as well.
Post #298816 14th Jan 2014 8:51pm
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
I bought mine from Uk Winchropes. Great service and great price
Post #298825 14th Jan 2014 9:07pm
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
Another thumbs up for the Bulldog spacers.
I would advise you go with the hub centric design if you are using alloys to keep everything nicely aligned.
Post #298829 14th Jan 2014 9:12pm
What puddle?
Simon: Ah, now, it's getting interesting. I read up on this, but I'll bow to any superior knowledge here... I went for NON-hub centric solely because I'm using high quality (Overfinch) wheels and, more crucially, the original wheel nuts - which 'should' centralise the wheel on the spacer. If using nuts that come with alloy wheels then it might be better to use 'centric' spacers. Is that right? Apparently, using non-centric spacers can mean that there is still a very tiny movement. But (as I understand it) using the original (OEM) wheel nuts means that the wheel is centralised and won't move. If I'm wrong then I have just wasted £110 when I could have gone for hub-centric at £50 more Whistle I hope I read-up right, but I have to say that the more I think about it, the more I think it might be that the wheel fits to the spacer fine, and it's the spacer that would move (very slightly) without being hub-centric. But then, why sell non-hub-centric ones then? Someone help before my head caves in. Now left.
Post #298858 14th Jan 2014 9:53pm
jst
if you want an offset it would get some rims made up to suit what you want rather than run wheel spacers. 5 nuts less to come undone. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #298859 14th Jan 2014 9:54pm
SimonDavies
My knowledge is far from superior Rolling with laughter
I do agree with you that the wheel nuts act to centralise the wheel. I may have overlooked this when purchasing.
I like the idea of having the hub centric spacer as well as the wheel nuts though. I think I paid £20 more. I was worried that fitting spacers would give a wheel wobble but I don't have any and thats with mud terrains.
I'm sure someone with more knowledge will be along shortly to correct us both Thumbs Up
Post #298863 14th Jan 2014 10:11pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I also got the Bulldog ones from Defender Bits and I am very happy with them.
Post #298879 14th Jan 2014 10:28pm
Rakeway.
Post #298944 15th Jan 2014 12:31am
BigWheels
I bought Paddock's own, but have been told by the last garage I went to that the bolts which attatch them (to the wheels?) are short & any looseness is risky.
So I need longer bolts..... Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #299203 15th Jan 2014 10:27pm
bear100
Just looked on the rakeway website and they offer a 30mm and 40mm spacer any pros or cons with either size?
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #299205 15th Jan 2014 10:33pm
Depends what wheels and tyres you plan on using really.
If running Boosts and 285s or 265s the 30mm spacers will keep the tyres in the arches but the 40mm will not, and to be legal you'll need to enlarge the flares. Narrower than 265 the 40mm spacers should be ok. It is unlikely that there'll be any significant performance, handling, or durability difference but I went for 30mm myself.
Post #299222 15th Jan 2014 11:30pm
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
The ones I had on my Discovery 3 were Terrafirma 30mm, billet and were very good. No issues with their fitting and also you didn't have to get the wheels re balanced as i hear you sometimes do for the steel spacers.
http://www.terrafirma4x4.com/products_php.php?cat=116&grp=26
Post #299233 15th Jan 2014 11:47pm
