Home > Off Topic > shot blasting - recycling abrasive.
Landy-Novice
hello all. Smile
we got a shot blasting business and we have a problem. the price of grit is quite expensive and we need to keep prices down for customers and the main factor is of course the grit! we need a way to collect, filter and return to the pot. we want to use reusable grit which is £1000 per tonne but for it to be viable, its needs to be filtered!
they use to use a huge hover which separates the dust from the grip into 2 bags, and just drop the grit back into the pot. i've been look for such a thing but had no luck. seen many industrial hoovers but i think hovering up around 200KG of grit/dust per hour will very soon kill it?
also found dust deputy. looks interesting but again. hovering large quantities of abrasive will i reckon just kill,
and indeed, dust extraction to remove most of the floating dust will really help. ATM we have one of these. which only has one 4" duct in a corner which is near useless! so were planning to add a length of soil pipe (3meters?) down the center of the booth with lots of holes to aid extraction which will hopefully improve visibility? is there a more efficient way to achieve max potential on our extractor?
next thing is abrasive recovery plants like this one and a low quality animation to demonstrate it here which are fully automatic and look the dogs whatsits but with a price tag of over 7K its a no go.
we are currently reusing the grit which is horrendous! its so dusty you cant see anything and it becomes less abrasive so it takes longer costing time/diesel and electric. use fresh grit is just delightful! cleans surfaces and you can see! Embarassed
does anyone have any suggestions/experiences on recycling grit?
thanks in advance. Very Happy
Post #298211 12th Jan 2014 9:11pm
Landy-Novice
no one? Question Crying or Very sad
Post #298430 13th Jan 2014 7:17pm
ARC99
When I worked for ICI as an apprentice I had to shovel the stuff back into the hopper on the small Shot blast plant.
The larger one just used to suck it up from a trough in the floor.
Dust extraction was when you opened the door. Don't make old people mad.
Richard
Post #298456 13th Jan 2014 7:50pm
