![]() | Home > Maintenance & Modifications > had a dynamat day today |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5998 ![]() ![]() |
Before
![]() Click image to enlarge After ![]() Click image to enlarge Andy |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2680 ![]() ![]() ![]() |
^^ That should make a big difference, especially on wet roads
Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
I'd steer clear of the Noisekiller bonnet liners.
Mine keeps peeling off and falling on the engine despite the fact I degreased the contact areas before installing. Glued it back loads of times without long term success. Also they weren't really interested when I phoned to ask how one (badly cut) piece fitted. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1455 ![]() ![]() ![]() |
Dynamat will be fine under the Bonnet
I just used spray adhesive and 3mm checker plate rubber matting from the bay ![]() ![]() Click image to enlarge |
[/quote]
Yes please Andy, very interested as this is near the top of my to-do list on my 110 utility. I'm most interested in what to fit over it so I'm not left with the dynamat writing all over the back.[/quote] I used some grey stretchable fabric from ebay and about 5 tins of fabric spray glue on my 110 hardtop. Thin flexible carpet is also an option. Search van lining or similar. Cut it dry to make sure it fits, then spray the glue and offer up to the Dynamat to be covered. Used a small wallpaper roller to firm it to the substrate. Not as messy as you'd think and the fabric I used was pretty forgiving. Pleased with the results but too dark for photos now. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Thanks for sharing Andy. Looks a neat job. I'd be interested to hear your opinion on the results.
Jim - that looks neat too. I would have thought 3mm wouldn't have followed the contours so well. Can I ask, is that a mudstuff panel ? Stephen |
Yep Mud stuff pannel
cozz Member Since: 15 May 2013 Location: nottingham Posts: 548 ![]() |
that chequer plate rubber looks nice
think ill do the same over my dynamat |
That's what I'm planning for my sides, will get it in the silver though, so it matches truck and is lighter.
Andy |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
[quote="bm52"]The Noisekilller blanket gets foulded under a Puma bonnet.
BM52, sorry I have to disagree with you on the blanket and puma bonnets. Mine has been happily in place with no issues of fouling the bonnet. It is a Noise Killer product that works very well in my opinion. _______________________________ Puma Defender 90 |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Hi Nobby,
No problem, mine crumpled at the rear and was wearing through on the near side where is rubbed between the common rail/bonnet. I guess this is down to good old LR gap fits differing between vehicles, etc, I had mine for 2 years and apart from the above had no problems with it, I went the Dynamat route to solve the above. BM52 |
