Home > Technical > Steering Wheel Lock
Gwynne_90
Steering Wheel Lock
Hi. Just tried to start my 2007 TDCi and I couldn't get the ignition key to unlock the steering wheel lock. Called the RAC as I was going nowhere and after gently giggling the wheel the steering lock came off and all was well. Now the steering wheel lock doesnt seem to activate at all - any suggestions or is there a gnack to this simple operation..... Thanks everyone.
Post #296654 7th Jan 2014 8:25pm
DAZ110
Just turning the steering wheel without the key in should make it lock....and you might have to wiggle the steering wheel as you turn the key to make come off again.
Post #296657 7th Jan 2014 8:28pm
landy andy
They are not the simplest to activate as the steering is soooo heavy without the engine running, especially if you've got big tyres Thumbs Up
Andy
Post #296674 7th Jan 2014 9:07pm
Gwynne_90
Turning the wheel, as you'd normally do, doesn't seem to work..... Any other ideas on what might be wrong?
Cheers everyone Thumbs Up
Post #296677 7th Jan 2014 9:12pm
jimbob7
It maybe it is coz your not used to the steering, requiring more force AND movement (there is a lot more play in a Defender) to turn the wheel,if you can turn the steering wheel from lock to lock without the key in the ignition then your steering lock is Censored . Pov.spec,ftw. 2006, 110,TD5.
Post #296685 7th Jan 2014 9:29pm
landy andy
Only thing I can think of is to jack the front up and try. If still nothing it must be damaged or broken.
Andy
Post #296693 7th Jan 2014 9:45pm
Leenorthants
Try laughing at it rather than giggling! Rolling with laughter
Post #296723 7th Jan 2014 10:37pm
