![]() | Home > Maintenance & Modifications > Instant gasket |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2965 ![]() ![]() |
Which one do you use
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 ![]() ![]() ![]() |
HYLOMAR UNIVERSAL BLUE GASKET
![]() stag wellseal jointing compound ![]() |
Agree.....
![]() HYLOMAR UNIVERSAL BLUE GASKET Use sparingly as can be a b45t4rd to seperate later. ![]() Treat every day as if it is your last....one day you will be right!! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8373 ![]() ![]() ![]() |
RTV Cheers
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
For general purpose use, blue Hylomar. Follow the instructions and you'll have no trouble. If the WSM specifies RTV, then RTV it is.
yes your right
but lots of people always use to much of any sealer and ive seen it knacker some very expensive race engines and auto boxes . and sealer hanging out of a joint looks untidy. hylomar because it stays soft gets sucked in oil pick up mesh and stays there sucked into wire mesh blocking them . rtv drys so doesn't get stuck into things and tends to stay at the joint its sealing . general rule is you only need to see the very smallest bead from any sealer pushed out of edge of the joint . if you can just see it pushing out when tightening then its done its the job .. MORE IS NOT BETTER sorry if it sounds I am telling some people there job .. but for some diy people its advise that may help them. Last edited by munch90 on 30th Dec 2013 3:08pm. Edited 1 time in total |
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
I just use the RTV I buy from GSF car parts - comes in aerosol cans and seems to be good quality but not expensive.
jonesie Member Since: 25 Sep 2011 Location: Petworth Posts: 231 ![]() ![]() ![]() |
Use RTV its what Airline Engineers use on Jet Engines......... Series I 86" Petrol orig side valve (daily hack)
VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
