![]() | Home > Td5 > TD5 oil check procedure |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6015 ![]() ![]() ![]() |
I've always checked mine when cold. Working on the theory, that if the engine is still warm (i.e just been ran) then oil might still be dropping back to a normal level??? 1999 Defender TD5 110
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
I always check mine when its cold.
When I first get mine in November from a dealer it was reading above the upper level but I have dropped about 3/4 litre and its spot on now ![]() |
Podrob Member Since: 20 May 2012 Location: Co Derry, N Ireland Posts: 31 ![]() ![]() ![]() |
From the owners handbook Oil level should be checked cold. If it must be checked with the engine warm the vehicle should stand for five minutes to allow the oil to drain back in to the sump. In my experience it will read slightly higher with the engine warm (assuming you have let it drain back in to the sump).
rsms Member Since: 12 Jan 2013 Location: Home Posts: 38 ![]() ![]() |
Thank you for fast responses - it is cold check then. I was a bit concerned as I`ve put only 7,4l of oil into and manual states 8,2l when changing both filters.
I generally put 7.5 litres in mine for an oil / filter change but always go by the dip stick checked cold. Even if you wait the recommended 5 minutes after running all the oil will not have returned to the sump.
