Home > Technical > Waeco heated seat kit
993porky
United Kingdom 2002 Defender 90 Td5 HT Baltic Blue
Hi there I've fitted the heated seat kit with ease to the actual seats,but now I'm stump as I know not about electrics
So I need help?
Basically I know how to fit switches etc but my problem is I'm left with
One red lead which is as book a direct supply from positive battery terminal ?
One orange lead which is as book connected positive terminal behind the battery ?
One black lead which is earth lead and book says is return line from the battery ?
Now what I thought was do I put a connector end on end of red lead and connect to positive on my battery
But what do I do with the orange lead?
And where best to connect the earth?
The instruction say put earth cable to vehicles earth bolt but where will that be?
I was hoping these three wires can all be connected in battery bay under seat to save routing wires all over the place
Any advice would be great
Cheers paul
Post #293393 27th Dec 2013 1:25pm
993porky
Took pic of wires but it hasn't uploaded ?
What am I not doing took pic on iPad and clicked upload before I submitted post?
Post #293397 27th Dec 2013 1:31pm
I'm not familiar with the Waeco kit but can tell you that an earth connection can be taken from most metal parts that are solidly fixed to the vehicle.
There is a threaded 'bolt' fitted to the floor of the battery box that you can use with a nut.
The red is probably a permanent live (ie straight to battery - but it MUST be fused)
The orange MAY be an ignition live that means the seat heaters only work with the ignition on
Post #293399 27th Dec 2013 1:39pm
993porky
FCX cheers for reply forgot to say both red and orange cable are both fused got ther own fuse in both cables
Post #293403 27th Dec 2013 1:49pm
That's good Thumbs Up
Take a pic of instructions and send to my mobile (number on my website)
Post #293404 27th Dec 2013 1:54pm
GUM97
Is this video of any use?
 An engine to TDi for!
Post #293406 27th Dec 2013 1:58pm
993porky
FCX hi just sent you a couple of pics
Thank u
Post #293407 27th Dec 2013 2:14pm
993porky
GUM97
Hi thanks for link good little video really helpful,I've had help from Matt (FCX) go beyond who has been a great help,so now I'm pretty confident about wiring them up Thumbs Up
One other thing though on video in seat box there seems to another little device were various wires get wired up to does anyone know what this is,just a thought but is it something to connect to positive on battery for future additions?
Thanks again for the replies, you can rely on getting help on here from everyone
Cheers Paul
Post #293420 27th Dec 2013 4:27pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
I installed this a few weeks back, in the battery box, but I did have to extend some of the wires.
Red is permanent live, orange is switched live. The switched live powers up the relay - ensuring the seats aren't left on whilst the engine is off.
Post #293434 27th Dec 2013 5:09pm
993porky
Diablo
Hi there so did you fix red direct to battery?
Did you fix earth into battery compartment in seat box?
And the orange what did you fix to?
I was going to connect the orange to the power feed at back of radio,curious to know what you done?
Also you got any pics?
Cheers Paul
Post #293465 27th Dec 2013 7:00pm
jst
i have these,
red straight to the battery +ve
black to an earth point or bat -ve if thats easier to establish.
orange - switched 12v supply. so to something that come on when the ign is turned on.
you could connect orange straight to the battery +ve too but if you leave the seats on they could flatten the battery Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #293497 27th Dec 2013 9:19pm
993porky
Hi JST
Cheers for reply this might be daft question but was does +ve and -ve mean?
Thanks Paul
Post #293510 27th Dec 2013 10:43pm
mk1collector
I don't wish to sound negative or mean, but please pay a qualified auto electrician to wire up the heaters as some of the questions you are asking lead me to think you could either blow your battery up in your own face or cause a fire. Sorry to sound negative but electrics can be dangerous if not properly installed.
Post #293521 27th Dec 2013 11:24pm
993porky
mk1collector
To be honest I'm fairly competent at most things so was just asking as if I got a good answer,which I've had many great replies then there isn't any reason why I can't connect three wires up once I know ( which I know now ) were they or were best to connect them,I always find its best to ask, you don't learn if you don't ask is my motto. Plus that's part of the fun with defenders adding bits yourself, don't get me wrong if it was a major job then I would get help Thumbs Up
Cheers Paul
Post #293525 27th Dec 2013 11:35pm
mk1collector
Thumbs Up I didn't want to sound condescending, I just didn't want you losing your pride and joy too a mistake Wink
Post #293532 27th Dec 2013 11:54pm
