![]() | Home > Td5 > Poor running after about 10 miles |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8347 ![]() ![]() ![]() |
fuel pump getting hot and not producing right pressure in rail? Cheers
jonesie Member Since: 25 Sep 2011 Location: Petworth Posts: 231 ![]() ![]() ![]() |
Thanks for that James.
It's now doing it from startup............ Series I 86" Petrol orig side valve (daily hack) VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
It should be easier to find the root-cause now if it's doing it straight away which is good news. Do you have or know of anyone in your area with a fault code reader? If you go through life with your head in the sand....all people will see is an ar5e!!
Thanks K9F,
Yeah it's been in to the local Indy ( Nick Kerner eng,) who claim it's been plugged in ...... Series I 86" Petrol orig side valve (daily hack) VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5982 ![]() ![]() |
New panel filter? Paper or oil?
Have you tried with MAF disconnected? Andy |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
If this helps...
If you can make the Oxon pub meet on the 8th Jan http://www.defender2.net/forum/topic25201.html I can bring along my Nanocom and we can check for fault codes and live readings. Appreciate you will probably want it sorted prior to that though... Jon - 110 td5 [sold]. Currently Defenderless. |
is the fuel pump making more noise than normal? whats the fuel pressure at the regulator? you can T into it and take a reading if your brave. Cheers
Thanks for those replies.
Air filter is a pipercross oil. Got to say I haven't tried it with the maf disconnected but will in the morning. The fuel pump seems the same.... Series I 86" Petrol orig side valve (daily hack) VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
Sorry forgot to add haven't checked the fuel pressure yet and it wouldn't make it Oxon at the mo because it is barley running. Series I 86" Petrol orig side valve (daily hack)
Makes in difference with the maf disconnected..... Series I 86" Petrol orig side valve (daily hack)
Probably a silly idea but have you tried it with the filler cap off?
The tank breather might be blocked. ![]() |
It was No1 injector........ Series I 86" Petrol orig side valve (daily hack)
