Home > Td5 > if you use lift hand indicate all light flash too |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
What...???
cheers simon |
21st Dec 2013 2:58pm |
deep down Member Since: 02 May 2012 Location: France Posts: 204 |
If all your lights are flashing when you indicate to the left, it sounds like you have a bad earth problem.
Check the connections to the indicators would be the first thing. |
21st Dec 2013 3:14pm |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 487 |
Damp and muck can get into the lamp holders/connections quite easily and cause that 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
21st Dec 2013 5:08pm |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 |
if you pull on wiring loom right hand side back end the problem can be made appear and disappear now to find out how fix it
New chases loom |
22nd Dec 2013 1:03pm |
It sounds like you've got a bad connection in that area somewhere.
Check all the connectors in that area, disconnect them, clean them with something like WD40 or contact cleaner and make them back up. If this doesn't cure it, move each wire at the plug connections until you find the one thats causing the problem. It will be something simple. |
23rd Dec 2013 8:02am |
thanks deep down have find the problem need to find away to get the loom out
23rd Dec 2013 8:22am |
Try disconnecting the tow socket from the loom underneath the right hand rear wheel arch (there's a plug behind a plastic panel in the rear wheel well) and spray contact cleaner in the loom plug. Check to see if the lights all work before re-connecting the tow socket.
23rd Dec 2013 10:59am |
