![]() | Home > Td5 > Centre console illumination Td5 90 |
Is that how they are wired or actually illuminated ?
If the latter and they are the push type switches then they have a bulb that is inside the switch. The front cover does come off and I believe that gives access to the bulb/led. Not sure if it can be replaced though, it may be hard wired. I can check over the weekend for you as I have a switch here in my spares box that I replaced the cover on a while back. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
It is indeed a hard wired led, they can be changed ( thinking of white myself) except the hazard switch which has the worlds smallest incandescent bulb
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
The hazard switch bulb can be changed too - there was a thread on here about it only last week. Darren
chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264 ![]() ![]() |
Thank you all, will take off front.......again!
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
The clear hazard switch bulb (STC1205) can be swapped for an orange bulb (STC1877), or a green bulb (STC1878).
The orange and green bulbs, used in D1/RRC and some Rover cars switches, are clear (3mm, wire-tailed) bulbs with a coloured 'condom' on them. These Silicon Rubber 'condoms' can be bought in other colours - http://stores.ebay.co.uk/dreamlixy2009/_i....=940834767 ![]() Alternatively, you can buy 3mm 'grain of wheat' bulbs in other colours, and fit them into the switch's bulb holder - http://www.ebay.co.uk/itm/111023874400 ![]() You can also paint clear bulbs with thinned modeller's enamel paint, or nail varnish. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
