Home > Td5 > How do I get the windscreen washer nozzle out?
Gareth
My nozzle is blocked up, and needs taking out for a proper clean or replacement. Before I start ripping the dash apart, is there an easy way to get it off?
I realise I could probably just pull it off, but its the getting back on that concerns me a little.
2003 model TD5 with newer style dash, and air con if that makes any difference. Thumbs Up 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #288747 9th Dec 2013 12:26am
They should be the same as the rear, which has a nut on it. So behind each there is a threaded section and a nut.
You might be able to get access just through the centre dash.
Thumbs Up
Might be worth trying a needle or pin downs the nozzles plenty of times too first. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #288748 9th Dec 2013 12:30am
wait until it gets cold and they pop off ...
they are a 2 piece unit, the outside bit pulls off Thumbs Up
Post #288765 9th Dec 2013 9:10am
Gareth
Cheers Chaps. Already tried the needle, and when I tried to re-align the nozzle a bit, the needle snapped off flush Sad
I guess I am going to give it a pull and see what happens Shocked 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #288768 9th Dec 2013 9:23am
Lou Sparts
i,m not sure but you may be able to get to the back of the washer jet on a Td5 if you remove the ash tray from the top of the dash. 2005 Td5 90 XS
Steve
Post #288769 9th Dec 2013 9:28am
Gareth
Ok, thats worth a look. Thumbs Up 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #288771 9th Dec 2013 9:39am
I removed the central pod then theres a screen held on with 4 self tappers easy access then
Post #288772 9th Dec 2013 9:46am
