Home > Maintenance & Modifications > 200tdi x brake
william127
200tdi x brake
Im going to get an x brake for my 200tdi truck, the 200 and 300tdi are different in that the 300 comes witha new cable. My truck needs a new cable anyway so if I ordered a 300 version, will it fit straight onto my 200tdi handbrake lever? Thanks.
Post #286913 1st Dec 2013 10:07pm
Anderzander
I can't remember the answer to this Shocked
But I'd you download the fitting instructions, I'm pretty sure it tells you. All I remember is that I bought a different cable, from x-eng, that fitted onto my Td5.
The distribution for x-eng products has been handed over to Foundry4x4 - so they are still getting used to things, but I expect they can sell you the right cable at the same time you buy the brake ?
Post #286928 1st Dec 2013 10:28pm
Litch
Bigest issue I had with the X-Brake when I got mine was that the instructions were for an ealier version of the brake than the one I was sent (same goes for the on-line instructions which I have just checked and see that they are using the same old photos). It wasn't vastly different but it did make me think (for a moment) that I had been sent the wrong model however a call to Simon soon sorted this out. The caliper has been rotated slightly so it is closer to the O/S chassis-rail, also the cable bracket is different and has two holes not the single one shown.
Don't forget to get your 10% discount with Landywatch. ONE LIFE, GET IT!
Post #287002 2nd Dec 2013 10:05am
The cables are all the same at the lever end (in the cab), it's the brake end where the 200 & 300 differ.
Post #287012 2nd Dec 2013 11:29am
