![]() | Home > Puma (Tdci) > what's broken today ?? |
If you have the original heated rear window with high level brake light, you will probably find a break in one of the elements as it passes underneath the plastic brake light cover. Later heated windows have the elements passing around the brake light cover. If you search on the forum other members have had this problem and have either had the window replaced under warranty or repaired.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Read this thread. http://www.defender2.net/forum/topic8507.h...ear+screen
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17935 ![]() ![]() ![]() |
The park switch is identical to the Td5. If you search on here you should be able to find a "how to" I wrote when I changed mine. It's a bit of a hassle due to the one-piece dash but can be done.
Wipers have to self park now for mot . ( not 100% its in force yet but sure if it isnt now -it's coming in )Might save someone getting failure ticket
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Just a thought- both happened at the same time? Maybe something has come loose/ rubbed through either in the back door or where the hinges are?
Glyn ![]() ![]() |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Regarding the high level brake light. It will probably be a break in the element in the driver's side beneath the cover. I folded a piece of tinfoil from a chocolate bar into a strip about two inches long and ran it from the soldered piece on the element outwards. I covered it with a piece of insulating tape, refixed the cover and continued on.Been working ever since. 1982 88" 2.25 diesel
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2066 ![]() ![]() |
Which chocolate bar wrapper would you recommend...?
Any one you can get off the kids! Had used a piece of wire as a temporary bridge but it lifted one day and one of the troops had some chocolate so I used the tinfoil. It's been 100% since
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Looks like a job best done at Easter time....!
I can perhaps post some photos to explain the technicalities of this repair.
dudley472 Member Since: 15 Nov 2012 Location: wolverhampton Posts: 96 ![]() ![]() ![]() |
the foil is a good idea, I've been messing about with this conductive paint with little joy, I found out the dog has been scratching the window
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
I have a couple of take out rear windows.... none dog scratched.
Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
How much are they Ian
I might be interested too, are CSW one's tinted?...how much? ....and will it survive carriage?
