![]() | Home > Td5 > Brake light problems |
fuse? Roel
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
Wired them the wrong way round, so the "brake" is coming on with sidelights? so when you press the brake, the (dimmer) sidelights are actually lighting, but you can't see them?
abiffen90 Member Since: 14 Nov 2013 Location: Gloucestershire Posts: 17 ![]() ![]() ![]() |
Cheers for you help, ill take a look. Wouldn't i had wired them the wrong way because its a simple clip on off.
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
I've seen a few posts that state you have to swap the wires round on LED's,sure someone will correct me if I'm wrong. Pov.spec,ftw. 2006, 110,TD5.
