Home > Td5 > Headlight dip/main beam relay buzzing and no lights! |
Domlandy1 Member Since: 20 Nov 2013 Location: Lake vyrnwy Posts: 4 |
Anyone able to help me please?
20th Nov 2013 10:09pm |
I'm guessing you're talking about a late '90's vehicle? I believe that the pink relay is part of the dim/dip system as the lights themselves are controlled directly by the switch rather than via relays. You're best bet is probably to isolate the dim/dip system completely (and throw it away as it's pointless anyway). Failing that, it's out with a multimeter, I'm afraid, to trace wiring and check for shorts. Darren
20th Nov 2013 11:03pm |
Hi there,
It's a 2006 130. Mm sounds like iam goin to be having fun with it tomorrow then!! Thanks for your reply |
20th Nov 2013 11:09pm |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
Sorted?
23rd Nov 2013 6:01pm |
Hi there,
Well nope not really, went to It the following day and all is fine except now there is no flash on the indicator stalk. Mm so no idea. Job for Monday now. It's ment to be goin to Anglesey early tues morn for a couple of days so don't want it dieing on them. Oh the joys of land rovers |
23rd Nov 2013 6:14pm |
