![]() | Home > Technical > Rear demister issue - TDI |
| Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335
Get a multimeter on the thing!
Check at the fuse box if power is at the fuse when it is off. I don't believe they are meant to have power permanently - only switch power (ignition switched). My initial thoughts are some sort of wire chafing or similar. Need to get the meter out and follow the power back really. |
