Home > Maintenance & Modifications > brake fluid
Tom DCab
United Kingdom 2003 Defender 110 Td5 DCPU Oslo Blue
brake fluid
The brake warning light (activated by handbrake) is now coming on permanently on my 2003 110.
i have checked the brake fluid and the reservoir is on low. I last changed all 4 sets of brake pads less than 10,000 miles ago. I can see no fluids leaks at the brake lines...
any advice from anyone on this?
thanks
Tom
Post #281879 13th Nov 2013 5:05pm
Dave-H
The warning light activated by the handbrake IS a handbrake warning light, which means either the handbrake is not fully released or possibly a switch issue.
If it comes on 'on its own' [not handbrake activated] then it could be down to low fluid ... if the brakes are not significantly worn, then top fluid back to MAX and keep a close eye on it for a week or two . Guns and Landrovers .... anything else is irrelevant.
Post #281881 13th Nov 2013 5:09pm
grafty99
It also illuminates when the brake fluid is low (it has two meanings) top up the brake fluid to the max mark and the light should extinguish 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #281882 13th Nov 2013 5:13pm
Dave-H
I know [amended post] .. But he said it was handbrake activated ... Guns and Landrovers .... anything else is irrelevant.
Post #281883 13th Nov 2013 5:15pm
grafty99
I think he means the light that is activated by the handbrake Question 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #281886 13th Nov 2013 5:16pm
Tom DCab
Thanks Guys,
Yes I meant 'the light that is activated by the handbrake'....
I think it is probably likely to be the low brake fluid so I will top it up and see what happens.
I guess as the pads wear, the level in the reservoir drops....
Tom
Post #281899 13th Nov 2013 6:29pm
grafty99
Tis true Thumbs Up while you're there check your clutch fluid aswel 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #281900 13th Nov 2013 6:31pm
jimbob7
FYI,the handbrake light is also a general brake error warning light,it also come on with ABS/TC warning lights. Pov.spec,ftw. 2006, 110,TD5.
Post #281903 13th Nov 2013 6:43pm
Merlin
There is a common fault where the cable rubs through and gives this symptom. Do a search for the thread.
Merlin
Post #282665 16th Nov 2013 1:36pm
The fluid level switch is very sensitive on my '07, unless the level is right on max the light flashes if you brake on a hill.
Top up the level and keep an eye on it. No need to worry unless you're losing fluid.
Post #282681 16th Nov 2013 3:17pm
