Home > Technical > What is a "header"?
jimbob7
What is a "header"?
I'm referring to a LR wiring diagram, specifically for ABS,it refers to a "header" (K109),in laymans terms what is a "header"? Am I right in assuming its just a shared earth point? Pov.spec,ftw. 2006, 110,TD5.
Post #281540 12th Nov 2013 11:39am
Martin
Site Admin
It's a block where multiple wires are joined together - not just earths.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #281541 12th Nov 2013 11:47am
Orangeboy
Little blue plastic junctions in the loom
This melted one was the cause of many intermittent lighting issues on my td5
Post #281566 12th Nov 2013 1:44pm
jimbob7
EEk,that looks nasty/\/\/\.
Thanks chaps. Pov.spec,ftw. 2006, 110,TD5.
Post #281902 13th Nov 2013 6:40pm
Orangeboy
Can't blame landrover for that , found many nails behind the dash one had got stuck and rubbed between the wire and dash
Just took a while to find.
It did not melt a fuse doing that oddly
Post #282001 13th Nov 2013 10:50pm
jimbob7
Ah, Landrover use nails when building Defenders,dint know that.That might be the cause of my problems......need to order moar nails. Thumbs Up Pov.spec,ftw. 2006, 110,TD5.
Post #282105 14th Nov 2013 1:41pm
