Home > Technical > Getting a bad vibe :(
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
Hi all, my 90 has developed a new vibration
Its a 2003 TD5 90 with a gkn overdrive (doubt that's the issue though) with 115,000
it started on Friday and i took note of it but thought id see how it progressed, it doesn't seem to be gear related as it will do it in 4th 4th o/d 5th and 5th o/d, although i can notice it it doesn't become really noticeable until 45mph after that i have a constant vibration through the seat floor steering wheel etc just as if im on rumble strips but i drive the same roads everyday with no issue.
i slid underneath at work today and loaded both props with grease to see if that would do any good and if it did it was very marginal, all the balance weights seem to be there and the uj's don't see bad, is there any comon issues to look for? any help appreciated thanks ed
Post #281306 11th Nov 2013 7:26pm
landy andy
Has it thrown its wheel weights off?
Swap wheels and see if vibration changes
Andy
Post #281321 11th Nov 2013 8:13pm
Millsy94
thanks its not wheel wobble though
Post #281326 11th Nov 2013 8:31pm
grafty99
I had a very similar problem, I ruled out UJ's but after much wiggling and pulling I found out it was a front UJ. The tiniest amount of play will cause a wobble Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #281350 11th Nov 2013 9:23pm
landy andy
Try removing one prop, test drive in difflock, then replace, and remove other prop, retest.
Andy
Post #281352 11th Nov 2013 9:28pm
Mdm
Sometimes the only and best way to see if you have a uj failing is to undo one end of each prop to give them a proper wiggle.
Simple things like checking wheel bearings and balancing wheels or even borrowing a set that is ok off another Car
Post #281368 11th Nov 2013 9:55pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
you can't properly check UJs unless at least one end is off. Unless they are completely fubar'd anyway.
Post #281519 12th Nov 2013 10:47am
Millsy94
Right an update, before I left work today I removed my front prop and ran her home in diff lock, well I don't know why but now I can't go past 30 without there being a resonance through the whole vehicle and the same vibrations as before. I forgot to mention in precious posts but it still only happens while under load, if im coasting its fine so I'm now looking rear prop or rear axle?? Ill try and take rear prop off tomorrow but now way in hell am I driving it far like it ( been there in a series 2) not too much fun just with a 2.25 petrol so no way with a td5. Any other ideas? Cheers guys. Ed
Post #281726 12th Nov 2013 10:01pm
grafty99
Sounds like the rear prop to me, the resonance and vibration being worse because all of the load is going through the faulty prop 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #281742 12th Nov 2013 10:24pm
Millsy94
Ill try and re fit front prop and remove rear prop tomorrow , it gets dark too soon. They don't go well front wheel drive. Hope it is the prop I don't wanna be paying out. Sad
Post #281745 12th Nov 2013 10:51pm
grafty99
When my front prop went I took it off whilst waiting for the UJ to arrive, mine has a strong stage 2 map by IRB and to say it was a handful in the wet would be an understatement Shocked 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #281746 12th Nov 2013 10:54pm
Millsy94
Haha I don't doubt it , my old series2 was fun enough granted it was a very re worked 2.5 petrol, though when I blew a rear half shaft front wheel drive was impossible to handle. She just slid and danced everywhere.
Post #281747 12th Nov 2013 10:57pm
grafty99
Although fun I can see why Landrover didn't do selectable 4WD when the power increased! RWD defenders are crap! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #281749 12th Nov 2013 11:02pm
Phatcat
United Kingdom 2002 Defender 90 Td5 CSW Java Black
I would bet on uj,s. had the same problem on mine , and as already mentioned it only takes a very small amount of wear to create a load of vibes.
Post #282213 14th Nov 2013 8:20pm
Millsy94
an update, as several of suggested i removed the rear prop to find that was the culprit, ive decided that i better get round to changing the spigot bush while shes stopped starting to wish i hadnt though Sad
Post #282753 16th Nov 2013 7:48pm
