Home > Maintenance & Modifications > Rose jointed trailing arms???
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
Hi all, i've seen increasing amounts of people converting their defenders to rose jointed rear arms, im currently on a std suspension set up though im working out what to fit with te suspension lift that im building up to, looking at these as my bushes don't seem to be lasting but would appreciate all your opinions as it is still going to be used on the road every day cheers Ed
Post #277117 27th Oct 2013 10:37am
Rose jointed give better "freedom" to the suspension, and allow it to flex more...
Just take a look at a standard setup; the trailling arm sits at a downward angle (from the chassis down to the axle) when the vehicle is sat level... just look at the chassis bush, it's already being deformed.
Once the axle drops, that stress on the bush is increased a lot. On my past 90 and current 110, i've put cranked trailling arms on, this means that the bush is sat neutral when the vehicle is level. and it gave me an instant extra inch of drop, just by the bush not binding up.
The rose jointed ones are good for challenge trucks. Not sure how well they wear though, as there's no rubber, it's metal on metal (or maybe a thin coat of teflon) and apparently, i've never driven with them, there is more road noise/vibration transferred up through the vehicle, especially once they're worn and a bit slack.
Post #277123 27th Oct 2013 10:55am
Laurie
I believe the MSA has banned them from all forms of off-road competition in Britain.
Post #277125 27th Oct 2013 11:06am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
rose joints are great for off-road but useless on road once there worn the play drove me mad with mine i changed to johnny joints alot better design and still has the elastic side of a conventional bush
if your doing lots of roa work dont waste your time with rose joints
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #277131 27th Oct 2013 11:40am
Millsy94
Thank you all for being brutally honest, johney joints??? never heard of them may just go cranked arms, while im here for a 50mm lift do i want castor correction?
Post #278385 31st Oct 2013 9:06pm
millepet
Belgium 2009 Defender 110 Puma 2.4 SW Orkney Grey
definitively YES! I installed the 50mm lift, and adjusted the camber 5 months later. These were 5 months of dangerous driving without great feel, and a car aiming for the scenery. It came back to normal behaviour after installing the OME correcting bushes.
Post #666092 21st Nov 2017 8:04pm
jst
johnny joints or rose joints wouldnt suit a road vehicle as suggested above, we use Johnny joints on the race truck and get through them pretty quickly
50mm lift, cranked rear arms would help yes, caster correction - if its just a road vehicle then yes. if its on large tyres/off road most the time then dont worry about it. clocking swivels is another way of doing it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #666478 23rd Nov 2017 7:38pm
