Home > Maintenance & Modifications > Side (tubular) steps - hot to remove?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi - any pointers on how to remove the side steps on a 110? Not the actual step type, rather the round, tubular type?
Looked on the lrpart.ru catalog (as well as popped my head underneath), seems simple enough but as I'm mechanically inept figured I'd ask here first if there is anything to watch out for. They seem pretty heavy, so I'm thinking that I should get the jack out to support them as they come off.
Post #275804 22nd Oct 2013 12:41pm
MartinK
This type? :
They are bolted to the sill (4 bolts I think), and two brackets on to the main chassis rails (bolted into captive rivnuts).
I would remove the bolts from the chassis end first (because gravity will hold them in place anyway), and then wedge the step up, and remove the bolts under the cill. No need to remove the fastening between the bracket and the step itself...
They're fairly heavy (maybe 15-20kg each), but not heavy enough to need a jack. I wedged mine up with plastic boxes and bits of timber when installing them..
So long as the bolts aren't rusted, it's a quick job to remove.
As mine,s a County, they didn't come as standard (as they do on an XS) so I bought them off a Forum Member (thanks AndrewS) and fitted them with new stainless fastenings (I needed them for my Mrs to get in and out - she's only 5' 2"). Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #275821 22nd Oct 2013 1:39pm
eutek
Yes - exactly the same! Thanks for the info. Thumbs Up Thumbs Up
Same here - Mrs. Eutek is only 5' tall, as is mum-in-law. If I didn't have these side steps we'd have to carry around a stepladder. Laughing
Post #275828 22nd Oct 2013 2:45pm
