Home > Puma (Tdci) > Puma help needed
Puma help needed
If anyone can help. A friend of mine in the next farm has a new-ish puma 2.2
He's getting a "whooshing" noise when he accelerates, and his sons scanguage shows P0101.
I've not had chance to go over and have a gander at it yet, stuck on lates tonight, but has anyone got a clue as to what it might be?
I suggested checking the air pipes for one that might have come off. googling that code shows MAF faults, but what would cause the whooshing noise?
cheers all.
Post #275601 21st Oct 2013 6:25pm
vodonos
Slovenia 2012 Defender 110 Puma 2.2 SW Sumatra Black
Mass or Volume Air flow sensor problems
Best ragards
bm BOŠTJAN
SLOVENIA
Cerknica lake
90 td5 2000
110 2,2 2012
Post #275618 21st Oct 2013 7:17pm
K9F
Mass or Volume Air Flow "A" Circuit Range/Performance
Split intercooler hose perhaps or insecure jubilee clip? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #275626 21st Oct 2013 7:33pm
bell-auto-services
It could be this issue which is getting more common. Or the hose could have come off at the turbo.
Post #275635 21st Oct 2013 7:52pm
Thanks all. gives me something to look at.
Pete... which hose is this one?? I seem to recall a thread on it some time back, but can't remember which one it was.
cheers
Post #275643 21st Oct 2013 8:27pm
ameliadunlop
We had exactly the same in our new Puma at the weekend. Ours was a split high pressure turbo pipe that had been rubbing on the alternator pulley. Apparently its a known fault with the new ones. Luckily ours is under warranty and the guy who came out from Land Rover Assistance said they fit the replacement in a slightly better way to avoid it happening again. I'm afraid that's as technical as I get but hope that helps. 2015 Defender 90 HT Corris Grey - Bowler Stage 2
2016 Discovery 4 SDV6 Graphite Santorini Black
Post #275645 21st Oct 2013 8:34pm
K9F
Would you not perhaps expect an accompanying P1102 Mass Air Flow Sensor In Range But Lower Than Expected and a MIL light perhaps with such a fault dependant on severity of leak of course or does the P0101 override it? Still surprised no MIL light though.
Diesel Jim....this thread..... Thumbs Up Thumbs Up
http://www.defender2.net/forum/topic20804.html?highlight=rubbing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #275662 21st Oct 2013 8:56pm
ameliadunlop
Should have said Embarassed we had MIL light although a good few miles after the hissing stared and when accelerating up a hill. Only code read was P0101. Now I really must bow out to those with far more knowledge! Razz Bow down 2015 Defender 90 HT Corris Grey - Bowler Stage 2
Post #275670 21st Oct 2013 9:08pm
bell-auto-services
Thanks for the link K9. You beat me to it hehe.
Post #275680 21st Oct 2013 9:22pm
Thanks all. yes, it was the pipe rubbed through. Thumbs Up
Post #275746 22nd Oct 2013 7:44am
bell-auto-services
Thumbs Up
Post #275756 22nd Oct 2013 8:31am
He's got a pipe coming from the local dealers, who can't get one until Friday! Rolling Eyes
You'd have though with this pipe being such a problem, they'd have them stacked on the shelves.
Post #275888 22nd Oct 2013 7:36pm
bell-auto-services
The problem is is that the new pipe is also a problem and I bet they can't meet build demand due to the failures of them. They have made the pipe a second time and its worse than the first hehe.
Post #275891 22nd Oct 2013 7:38pm
