![]() | Home > Technical > 2008 2.4d 90 pick up immobiliser |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076 ![]() ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6053 ![]() ![]() |
Would think it will have, and is a standard item.
Do you have any dash warning lights? Andy |
Try Topix. Free to register. Then enter full vehicle VIN number and you will get the build profile of that particular vehicle.
http://topix.landrover.jlrext.com/topix/vehicle/lookupForm ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Thanks for that will try
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Fitted as standard (i.e. alarm unit a.k.a 10AS unit) - but probably not active if poverty spec.
Easily done with the correct diagnostic equipment... can even wire in the ultra sonic sensor etc. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Thanks Ian for the reply.
the dealers are fitting one this week as not insured without. I would of thought everything had an immobiliser as standard the last ten years ![]() steve e |
All Puma's have the alarm/immobiliser unit, so unless your insurance needs a CAT 1 it is already there...
All you need to pay for it to have the settings changed, fobs/programming and a reluctor ring fitted if needed... and then up to you if you want the ultra sonic sensor. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Thanks For the info Ian
