![]() | Home > eBay & Bargain Spots > ABS modulator...... for a Puma :( |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
As above, on the bayE,if yours ain't broke it soon will be,lol.
http://www.ebay.co.uk/itm/261307214028?ssP...1438.l2649 |
Lol,no not mine, I have a "passing interest" coz my pumps playing up (TD5).
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
I have the three amigos on a puma,
computer reads: "valve sticking" Dont know what to do with it :L William |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
MOT fail now apparently.
That's destroying
Thor Member Since: 17 Dec 2011 Location: Didcot Posts: 446 ![]() ![]() ![]() |
William8, like jimbob I had an interest in abs modulators for a while as mine went on my TD5. If you have the 3 warning lights on your dash it won't go through the MOT.
Before you leave it to long try getting in touch a company called ECUtesting (www.ecutesting.com), they maybe able to repair for around £200 but you have to remove it and send it to them. I left mine for ages and by the time I got to the mot it was unrepairable, so had to fork out £1,200 + vat.......sad times!!!!! My advice is get it sorted ASAP, as you may reduce the cost! Strong people are harder to kill and generally more useful! |
Just rang them up there, sound like the men for the job
![]() Just need to work out how to get it out of its hole now ![]() |
Did you have the codes cleared when they were read,sometimes they don't come back on.Also found a guy who makes abs delete/removal kits,but I'm unsure as to whether you can clear the warning lights afterwards,meh!
Im going to whip the pump out tomorrow and post it to ecu testing.
I would like to keep the abs as standard and rather than pay the £2200 for a new one ecu quoted me £300. William |
abomb1969 Member Since: 23 Jul 2011 Location: Welwyn, Hertfordshire Posts: 79 ![]() ![]() ![]() |
The guy I saw today said don't let the air get to the internals if you remove it.
I would presume they self prime from the brake servo do they not?
The modulator lies slightly below it so it should drain down. I have heard of a 'prime' function on the computers but was just going to try the self bleed. William |
On Nanocom,Lynx and I assume Hawkeye you can do a modulator bleed as well as a power bleed.
Just heard from ecu testing. Need a new pump
