![]() | Home > Td5 > Mirror door hinge removal? |
If you take the door trim off and open the window you gan get to the nuts at the back of the top hinge. Just undo the two on the door side of the hinge itself and the hinge will swing out with the mirror attached with two screws from the inside of the hinge.
Hope that made sense Ray |
Hock Member Since: 12 Sep 2011 Location: Yorkshire Posts: 133 ![]() ![]() ![]() |
right, so the nuts on the inside are loose, cheers for that
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8407 ![]() ![]() ![]() |
yes nut on the door inside are loose. the ones on the bulkhead are captive, but it is best to undo the door ones. so you dont have to reset the position of the door.
loctite the arm bolts back in too. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
When you've taken the trim off close the door and then undo the hinge bolts so the door doesn't need re-adjusting. When you've done the mirror just bolt it all back together before you open the door.
