Home > Maintenance & Modifications > protecting rear x-member from spray
Cheshire110
so im going to get around to waxoyling my defender before the winter, so sometime soon hopefully!
and im going to sort some of the excellent looking mud dirt defenders to stop the annoying spray up the side, but;
i want to know if theres anything i can fit to stop the rear x-member being filled with mud, dirt and salty water and stripping away the waxoyl and eventually the metal? its so depressing to see a freshly waxoyled & painted rear crossmember dripping with brown mucky water out of the holes in it...
ive seen something like that for the front, to protect the outriggers? but is there a rear equivalent, or an easy mod i could make? Cheers, David
Post #273768 14th Oct 2013 7:36pm
Cheshire110
image below should show the 'thinning' of the paint that im sure this problem results in, but what you cant see is inside!
 Cheers, David
Post #273771 14th Oct 2013 7:40pm
Cheshire110
hmm its upside down? you get the idea anyway... Cheers, David
Post #273772 14th Oct 2013 7:44pm
GUM97
If you keep it that way up, the water would run out pretty quick? Whistle
In all seriousness, you could perhaps fit some sort of plastic shield/guard to the back of the crossmember to avoid to spray? An engine to TDi for!
Post #273778 14th Oct 2013 7:52pm
Cheshire110
yeah or cling film!
i might try and get some thick plastic sheeting and see if i can whip something up Cheers, David
Post #273809 14th Oct 2013 8:26pm
Likeomg
im considering plasti dipping the under side of my car...
for anyone that hasn't heard of plasti dip http://www.youtube.com/watch?v=UdCtzxkER7k
would dry it out, give it a few washes without it moving leave it to dry over a few days with the heating on in the garage then just cover the underside in about 5-10 layers of this
did my steering guard matte black a few weeks ago, came out great
Post #273817 14th Oct 2013 8:34pm
Cheshire110
seen it a couple of times, it so cool!
is there a uk supplier yet or just online?
ideally id wander into halfords and have a look face-to-face... Cheers, David
Post #273827 14th Oct 2013 8:49pm
GUM97
Online only at the moment I think! I've got a ruck of it in the garage ready for a little project... An engine to TDi for!
Post #273828 14th Oct 2013 8:52pm
Likeomg
i purchased from plasti dip uk... its been on about 2 months no problems, cant say long run yet but with the winter predictions theres going to be a lot of salt about...
Post #273829 14th Oct 2013 8:53pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
I've used this 3M product on my motorbike and it's really good.
http://www.venture-shield.co.uk/
I think they do a matt finish which would probably look best on a cross-member.
You can buy it off the roll (as I did) and just cut it to size. Not cheap per sq.m. but it wouldn't cost much for what you're talking about.
Wouldn't do internal protection but would keep the back clean. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #273852 14th Oct 2013 9:43pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
you could always adapt a front inner arch to fit the back that would do the trick 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #273857 14th Oct 2013 9:51pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Wipe over with ACF50, works a treat.
http://www.acf-50.co.uk/acf-50.htm LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #273859 14th Oct 2013 9:57pm
Cheshire110
thanks for all the tips guys, i dont have the car in front of me at the moment (im at uni :/) but ill have a look at what can be done when i go home
wow, plastidip is so cool - i need to find a need for it on my car! Cheers, David
Post #273884 14th Oct 2013 10:20pm
Cheshire110
Would this be suitable to coat the lower half of the sides of my 110? To protect from Greenlaning scratches? Hmmm..
Any estimate on price /m^2 or where to buy? Cheers, David
Post #273894 14th Oct 2013 10:32pm
Likeomg
both of my mountain bikes are covered in that tape its also known as helicopter tape (or a very similar product is) theres a few knock off's some which yellow in sunlight, 3m doesnt... protects the frames / forks etc on uplift days and from stone chips
Post #273899 14th Oct 2013 10:36pm
