![]() | Home > Off Topic > Good drill bits? |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21042
Not suitable for all purposes but have you ever tried a step drill bit? I find they are excellent little bits of kit. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336
Try Dormer, Presto, Sherwood, Heller HSS and use a cutting compound
| SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455
Machine mart do a good set - Ti Nitrate coated which I use in my milling machine and lathe without issue.
Agree ref step drills for sheet. My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
| Generaldej Member Since: 30 Dec 2012 Location: Milbury Heath Posts: 82
I got a box of 170 drills from Axminster tools - 1.0 to 10.0 in 0.5mm steps. Used on most metals including stainless steel but you must use cutting fluids to ensure longevity.
Click image to enlarge |
| Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596
Has anynoe tried a set of those drill bits that you see the guy selling at most of the LR shows. Drills all materials and guaranteed not to break.
I have a set of Heller HSS from Machine Mart and they seem good. |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
^^Yep I've got a set from the bloke at the Landy shows- great bits! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006
We Have 3 sets of heller one imperial 2 metric. Apart from snapping the smaller ones in pistol drills by being rough we have not had any problems also our local ironmongers sell them separately which is good. Rhubarb and custard let fly with their secret weapon.
| yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714
We use guhring drills or dormer for drilling all types of metals inc. stainless steels. Try J W Tooling based in Southampton for supplying them.
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Thanks Guys!
A britpart steel mud flap bracket should not defeat a drill press... Will have a look tomorrow! |
| madrunner Member Since: 24 Jul 2012 Location: Dorset Posts: 68
I use cobalt bits which have always drilled everything I've ever needed to pop a hole in.
Good oil makes a huge difference - I use rocol. Awesome stuff. |
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027
Try Hilti awesome kit
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
| WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748
I need a decent set of masonry bis, any suggestions please?
| AWOL Member Since: 31 Oct 2013 Location: UK Posts: 222 |
DeWalt bits in a SDS drill seem to go through pretty much any masonry like a hot knife through butter.
Not sure if it's true of all SDS bits, but they seem to last MUCH better than any bits I've used in a conventional percussion drill. Incidentally, for anyone interested in Cobalt bits for metal, Toolstation do a useful Heller set for about a tenner. I use then, run fairly slowly to avoid excess heat and with oil, on stainless parts for my other car and have found them to be really good. |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
We spend day after day drilling steel/ally and concrete. So from experience Dormer for steel and ally, Hilti for concrete.
| All times are GMT |
