![]() | Home > Maintenance & Modifications > Help needed - mantec storage cages |
| SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244
Does anybody have any experience with the storage cages mantec produce.
A forum member has the pre '02 for sale but my vehicle is post. Can anybody confirm that they can be adapted. It's a long way to drive and a lot of money to me to find they ate useless to my vehicle. Much appreciated. |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
If you have a TD5 they will be fine. I have the pre 2002 fitted to my post 2002 TD5 and they fit perfectly. If you have a TDCi they will not fit due to the wheel arch shape.
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
| SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 677
Just to add that not all TDCI models have the cut out in the wheel arches for the forward facing seats.
Good point Steve
If the wheel arches are the 'normal' 90 degrees on top then they should fit OK. They are designed for a 110 but I have them fitted in a 90, they just needed a little trimming at the rear. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Steve G - "just to add" ... confusion?
My fault, I have have put some detail in. I have a 90 tdci hardtop with no cut outs in the rear. With this in mind, going by what Bob has mentioned, they should fit? Thanks for the replies also. |
Thanks Bob, I have just seen your post.
It seems they are worth a punt then. |
They certainly are
Have a look below Click image to enlarge I had to trim about 10mm off at the back door edge to get them to fit. You will not notice the cut line at all. If you don't have the bulkhead removal bar and lower dog guard then I think they will fit straight in, in fact with the BH removal bar and without the lower part of the dog guard they should be a straight fit. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
This gives me confidence. I have pm'd the seller, just need to agree on a price.
I will let you know when (hopefully) they are fitted. Thanks again both. |
| All times are GMT |
