![]() | Home > Maintenance & Modifications > What Can This Be? |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
That will be your clutch master cylinder leaking. But change master, and slave. Easier to do both at once
Andy |
| DRW58 Member Since: 23 Feb 2013 Location: Perthshire Posts: 167
Thanks sounds like a trip back to Tayside Landrovers.
My TD5 is getting more and more like Triggers Brush every day. DRW I built a garage for my Mini With a place for everything and everthing in its place. Ten years down the line there's a Mini in there somewhere, and |
| MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 692
Be care of the fluid - it can "remove" paint when not cleaned properly. Same like brake fluid.
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Its a realy easy job, I did mine at home only needed a spanner and socket set.
Probebly about 2 hours at most from bonnet up to test drive. |
Got a good price from Matthew Webster at Tayside Landrover so happy to et him bash his knuckles.
| All times are GMT |
