![]() | Home > For Sale & Wanted > [Wanted] reverse light 2002 in LED |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
Mobile Centre (forum sponsor) sell them...
http://www.mobilecentre.co.uk/index.php?ma...cts_id=406 "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Will an LED have a better light output?
Not necessarily. Cheapest solution is to tell your wife to switch on the hazard lights as they give a much better spread of light then just the reverse light Depending on where you reverse you may well require good wide angle light pointing out at an angle to rear of the vehicle. Even better if they are mounted at roof level Consider one or two LED such as the 900 lumen vision X solstice lights at roof level and separately switched to the reverse light. OK such a system is not road legal in the UK, but they can also double up as a work/camp light and will be brighter with a better spread of light then a reverse light. Brendan |
| Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439
I fitted a 16w cree LED lamp in my reversing lens.
The effect is like a mirror ball at a disco (not Disco). Brighter pinpoints of light but no overall increase in backwards illumination. Quite pretty though. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
As Brendan already commented, LED reverse lights are not doing wonders either. My SVX came standard with LEDs, and when you look at the reverse lamp when it is on from the back of the truck, it seems extremely bright. But when at night you actually reverse the truck, it is surprising how poorly that LED lamp illuminates what is behind the truck. Using the hazards can indeed help, but I also find that using my LED rear fog lamp when reversing really helps a lot. For some reason the light output of my LED rear fog lamp seems much better than of the LED reverse light. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| dwardu110 Member Since: 23 May 2013 Location: mgarr Posts: 35
tks for replies... ohh how much I had in mind that led light would be brighter!!
on my 100inch for offroad I have one of these fitted.
..... it does it job great!! massive light.... somehow on my basic 110 I feel its no place for something similar!! strange mind |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219
^^^^ What make/model is this light?
no idea diesel Jim........ bought off e bay a couple of years ago...this should be link to supplier
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...TQ:GB:1123 |
| All times are GMT |
