Home > For Sale & Wanted > [Wanted] Td5 soundproofing, rear trims |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
Got Dynamat in stock Will CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
26th Sep 2013 7:39am |
Will,
What window trims are you after? I've just had Landyglass fitted and have the two small windows at the rear either side of the door and the trims. You can have them for post and packaging if you're interested. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Sep 2013 7:43am |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 148 |
K9F
Not wanting to step on any toes - but If the small rear plastic trim is no good for Will, could you bear me in mind please Regards Les |
26th Sep 2013 5:36pm |
Will do! Just need a response from Will first! If you go through life with your head in the sand....all people will see is an ar5e!!
26th Sep 2013 6:12pm |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 340 |
sorry peoples, what i mean is the interior grey trim that gets used in csw's, i have landyglass myself and wanted to finish off the inside.
27th Sep 2013 2:30pm |
Les/Will,
Apologies I read the post wrong. I thought by the trims you meant the rubbers. Sorry..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
27th Sep 2013 2:40pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Look at LA-Salle trims
27th Sep 2013 3:01pm |
