Home > Maintenance & Modifications > Body Tape recommendations
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Hi All
I've got a set of those Mud defender wheel arch spats to fit on (when I've painted them - Thanks Dan for sorting out the paint Thumbs Up )
I was thinking maybe its possible to fit them without drilling initially (just in case I /mrs H doesn't like them or they don't work - unlikely I know)
So I'm wondering if anyone could recommend a body tape which would be decently strong so they don't fall off at the first bump - maybe something like number plates are stuck on with, but a narrow strip? Preferably easily available on the high street!
I guess the other option is an adhesive like no more nails or similar but if anyone can recommend a tape that might be tidier. Then as well as sticking them on they would be sealed to the body.
Looks like the sidesteps might have to come off to fit the front ones anyway Shocked
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #267926 19th Sep 2013 4:45pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
I've used no more nails tape for number plates. That should work for a temporary fix to see if you are happy with them and it doesn't damage paintwork. Both surfaces would need a good clean with a degreaser first, and a rub down with diluted IPA before applying though.
Steve
Forgot to mention that you can get it from most DIY stores
Post #267928 19th Sep 2013 5:10pm
JWL
I was going to say cling film, but that's an answer for a different forum. I've used exterior use silicone sealant for number plates and the like before now, the slight elasticity helps with things being vibrated off. I broke a number plate that I'd stuck over a previous plate on my caravan when I sold the van and it had been on for three years!
Post #267929 19th Sep 2013 5:15pm
Lou Sparts
3M do a range of double sided tapes for sticking on body mouldings etc.
It would be available from bodyshop suppliers or possibly e bay. 2005 Td5 90 XS
Steve
Post #267930 19th Sep 2013 5:17pm
mk1collector
As above 3m when I worked in bodyshops we used 3m double sided for resticking body mouldings etc but make sure the area to be stuck too is thoroughly clean and grease free.
Post #267931 19th Sep 2013 5:27pm
