![]() | Home > For Sale & Wanted > [Wanted] Wanted 10AS alarm ECU ending 280 |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
You can piggy back a remote c/l relay off the multi plug on the relay, bought off fleabay or if you're adept with circuit boards, solder a relay off a scrap disco board onto your board.
Keith ![]() |
Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
"You can piggy back a remote c/l relay off the multi plug on the relay, bought off fleabay or if you're adept with circuit boards, solder a relay off a scrap disco board onto your board. "
I feel like Cletus on The Simpsons.......! Mind you, i'm getting used to it. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
You've lost me there Cletus!
http://www.ebay.co.uk/itm/Central-Locking-...4ab41fdc78 This is the one I used - works utterlydiidlydacious! Flanders |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
O/T
Care to give the pin connections of what you did? ![]() |
https://twitter.com/cletus_d
Thanks but for the money the xxx280s seem to have been available for in the past, I'd still go with a new unit. I hate/am no good at soldering.. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
Jim - I've photos somewhere - I'll search
Simon, three years ago the 280s were £130+ & for a tenner and an hour got the CL working perfectly, good luck Keith |
Ah. The last 280 I saw on ebay (hadn't worked out I needed it) in August was £39 + p&p
http://www.ebay.co.uk/itm/151087331497?ssP...1423.l2649 There's a 270 thats been on offer for ages at £75 buy it now but no interest. If you're right it's out with the soldering iron but I'm hoping someone on here might have one. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
![]() Click image to enlarge ![]() Click image to enlarge Here's the two photos of the connections on the pcb - I'm sure they will give the electronics experts on here palpitations, but still going strong after three years! As long as you don't want to know where they connect to on the relay.....I can't find that photo, but if needed I can drop the relay and check, from memory, its easy to check where they go to with a 50:50 chance on the open close circuits. If you haven;t realised its possible to fiddle the ecu out through the speaker hole, speeds things up! Keith |
