Home > Puma (Tdci) > DPF warning symbols on a 2.4TDCi
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I took my instrument cluster apart this morning to investigate the apparently unused space below the fuel and temp guages, with a view to filling it with some form of useful information. Possibly Int/Ext temp or TPMS.
I found there are 2 LEDs and symbols for what appear to be DPF warning symbols.
https://www.dropbox.com/s/fl6sis095mb3xlu/P1100097.jpg
My Defender is a late 2010 model with the 2.4 engine, so is it safe to assume these lights will never come on, or should I make provisions for them on whatever I end up making?
Cheers,
Mark
Post #266546 14th Sep 2013 8:37am
K9F
Is it possible to whip out the LEDs and use a multimeter across the terminals to check the resistive reading of any circuit? Alternatively just leave whatever is attached to the LEDs stored behind the dash and use the vacant space anyway. That way you can always revert back very easily should the need arise later.
They're not used on my 08 2.4 and I don't know if the LEDs are even there! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #266552 14th Sep 2013 9:01am
Caterham
I'm fairly confident to suggest NONE of the 2.4's have dpfs.
Post #266555 14th Sep 2013 9:41am
K9F
Are you sure Caterham? Could be your DPF is goosed and the lights are inoperative, you may have an issue that needs looking at utilising lots of your time?
Rolling with laughter Rolling with laughter Bow down Rolling with laughter Rolling with laughter
Just for clarity NO DPF or system monitoring functionality on a 2.4. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #266563 14th Sep 2013 10:29am
Caterham
Shocked
I knew something wasn't quite right .... having checked in my V5 mines actually a 2.402. perhaps mine does therefore have a dpf Big Cry
I need to get it to the dealers before warranty runs out for a couple of other things door lock and fuel breather pipe. I'll ask them to check out the dpf and warning lights.
Thud
and I thought everything was going well ? Big Cry
Post #266565 14th Sep 2013 10:35am
Caterham
Post #266567 14th Sep 2013 10:36am
K9F
Thumbs Up Laughing
Glad to see you're happy of late, roses are blooming in your garden and you still have a sense of humour. Brilliant!!!! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #266568 14th Sep 2013 10:37am
Caterham
not only did I very nearly loose my sense of humour but my marbles too.
- one of the best was taking the regional LR technician, service manage and work shop manage out for a drive only to be told that the noises were normal / characteristic.
that night I find heat shield bolts and heat shield brackets missing shortly before the gearbox failed !
sorry - OFF TOPIC.
but as you say all good now. Thumbs Up
Post #266569 14th Sep 2013 10:43am
BigWheels
Reading my owner's handbook, there is an over-speed (120 km/h) warning light that comes on for Defenders used in the Gulf States, its in the bottom right corner (pages 47 & 49). Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #266663 14th Sep 2013 4:52pm
